My LED finder checklist
NWdude83
1) Price Range: An easy question, but you may change your mind after answering the rest! :)
____I only want to pay $1-10.
_X__I can spend $15-30.
_X__I could spend $40-60.
____I am willing to spend $80-$120.
____I have no limit!
2) Format:
_X__I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a portable spotlight.
3) Length:
____I don't care.
____1-2 inches. (Keychain sized)
____2-4 inches. (Pocket carry)
_X__4-9 inches. (Holster carry) (more like 4-8" tops!)
4) Width:
_X__I don't care.
____I prefer a long narrow light.
____I prefer a short wide light.
5) What batteries do you want to use? Alkaline batteries are easier to find and less expensive but don't pack as much stored energy and are don't work well in cold temperatures. Lithium batteries have long shelf life (10+ years, great for stored emergency lights) and are not as affected by cold but must be kept dry and are more expensive. Rechargeable start expensive, but if used frequently pay off quickly.
_X__I want common Alkaline batteries. (AA, AAA, C, D)
____I want lithium batteries. (coin cells, CR123, AAA, AA...)
_X__I want a rechargeable system. (an investment, but best for everyday use)
6) How much light do you want? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to read a map, or find a light switch, in a dark room. (5-10 lumens)
____I want to walk around a generally paved area. (15-20 lumens)
____I want to walk unpaved trails. (40 lumens)
_X__I want to do Caving or Search & Rescue operations. (60+ lumens)
_X__I want to light an entire campground or dazzle an intruder. (100+ lumens)
7) Throw vs Flood: Which do you prefer, lights that flood an area with a wide beam, or lights that "throw" with a tightly focused beam? Place an "X" on the line below.
Throw (distance)---------------------X--------------------Flood/close-up
8) Runtime: Not over-inflated manufacturer runtime claims (like some LED lights). but usable brightness measured from first activation to 50% with new batteries.
____20 min. (I want the brightest light for brief periods)
_X__60-240 min. (1-2 hours)
_X__240-360 min. (4-6 hours)
____360+ min. (More than 6 hours)
8) Switch Type:
_X__I don't care.
____I want a sliding switch. (Stays on until slid back.)
____I want a "clickie" switch. (Stays on until pressed again.)
____I want a momentary switch. (Only stays on while held down.)
9) Switch Location:
____I don't care.
_X__I want a push or sliding switch on the body near the head.
_X__I want a push switch on the back end of the body.
_X__I want a rotating head switch.
_X__I want a rotating end-cap switch.
____I want a remote control.
10) Operational Modes: Check all that apply.
_X__A simple on-off is fine for me.
_X__I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
____I want multiple light levels. (some lights have 5-16 light levels.)
____I want a strobe mode. (blinks to show location.)
____I want a tactical strobe. (Flashes rapidly to disorient an opponent.)
11) Is it important whether the body is metal or plastic/composite?
_X__I don't care.
____I want a metal-bodied light.
____I want a plastic/composite light.
12) Special Needs: Is there anything else you want or need that hasn't been mentioned? Circle any below or write in your own comment(s).
____Red (night vision preserving) filter
____Other filter colors (Amber, Green, Blue, _________)
_X__Waterproof – how deep: _X_rain or __drop in puddle proof
____Non-reflective/dark finish (stealthy/hard to find)
____Polished silver or brightly colored finish (for easy locating)
____Corrosion resistant or hard-anodized finish
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Built-in second (or spare) lamp or filament
____Belt/Jacket clip
____Holster
____Wrist/Neck Lanyard
____Kobuton/self defense features
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
