Hey guys I'm new here and i have lots of questions about LED's! Please bare with me on this! Instead of multiple threads i will make this One thread for all of my questions!
Here it goes guys!
Question #1
What i want to do is make address signs for me and my family. I would like to use LED's to power/light the sign. I will be using a Light Dard Relay (LDR) so it will come on only at night. I need suggestions on how to do the lettering/numbering on the sign. I thought about many ways. The way i would like to do it is by using tubing. I have seen this type of tubing where you put the LED in the end and it has some type of chemical or gas? that picks up the light and sends it further through the tube. I found the product i was talking about here it is. ://www.bivar.com/docs/news/?p=smpt I also need suggestions on how to make a holder for the address sign. Any suggestions will be considered!!
Question #2
I currently use 5mm LEDs and when i make them i do the usual way. I solder the resistor to the LED pigtail and then i solder a lead wire to the other end of the resistor. Now what if i want to make ten LEDs wired to a single positive and negative what would the best way to go about that? i have tried wiring four LED's into a single positive and negative and it was a pain in the butt to solder that many wire's together! what other ways are out there to go about this??
Thanks much guys. I really would like to know these two things at the time
:wave:!
Here it goes guys!
Question #1
Question #2
:wave:!
