My Luxeon gets golden
win67
win67
Karlsruhe, Germany
What's that? The Luxeon I inside my Fenix L1P gets visible golden, round the die/phospor of the emitter, where it is normally silver plated...
Never seen this before....
Jens
monkeyboy
monkeyboy
UK
That's just the reflection of the phosphor. It just means the reflector is doing what it's supposed to do.
E
evan9162
Boise, ID
I have a lot of older luxeons that are doing this too.
The silver turned gold part you are seeing is the top of the heat sink slug of the emitter. The hexagonal shaped silicon submount is thermally attached to the top of the slug, and the square shaped die (covered by yellow phosphor in the case of white Luxeons) is attached to the top of the silicon submount.
The heat sink slug is copper plated with silver. The silver is likely tarnishing. I have several luxeons with many thousands of hours on them that are exhibiting the same phenomenon. The silver is tarnishing on the top of the slug. It's not a result of poor thermal management (the luxeon is not getting overly hot) since many of mine which have tarnished have excellent heat sinking and only get a few degrees above room temperature.
I don't think there's anything to worry about. The silver on the top of the slug tarnishing won't affect the device in any way.
jtice
jtice
West Virginia
exactly what monkeyboy said,
if the reflector is filling up completely with the reflection of the LEDs yellow phosphor, then its designed well.
Some reflectors dont use their entire surface area to actually reflect the LED.
~John
win67
win67
Karlsruhe, Germany
evan9162,
so I'm relaxed now... Thank You!
But no more reason to mod it to a SxxH :-(
Jens
E
evan9162
Boise, ID
~John
He's not talking about the phosphor reflecting in the reflector, he's talking about the tiny silver ring around the phosphor that's part of the emitter its self - the top of the heat sink slug.
I will post macros tonight to show the difference.
EngrPaul
EngrPaul
PA
Jens
It's oxidation from singing into it. Save it for karaoke night and use a real mic.
monkeyboy
monkeyboy
UK
OK now I get it :ohgeez:
That would make a lot more sense for the start of a new thread.
HiltiHome
HiltiHome
Germany
I'm singing in the rain...:lolsign:
E
evan9162
Boise, ID
Here it is:
These two luxeons are the same age, from the same tree of stars. The one on the left only has ~100 hours on it, and has been in a bin in my garage for 3 years now. The one on the right has been used ~2 hours/day nearly every day for 3 years in a set of lanterns in my living room. There are 9 others in that set that are also tarnishing. These are the only ones that I've noticed that have tarnished, but are the ones with the most use (several thousand hours).
E
evan9162
Boise, ID
Here's the tarnished one all by its self:
WildChild
WildChild
Québec, Canada
Does it dimmed much or it is still going strong? Well cooled?
E
evan9162
Boise, ID
Haven't noticed any dimming. They are all attached to a 3"x3" or 4"x4" 1/16" aluminium plate. The 3" sq plates run about 5C above room temp, the 4" sq plates run only 1-2C above room temp.
LEDcandle
LEDcandle
Mushroom S'pore
Well as they say, "Old is Gold".. I guess they meant it for Luxeons too.... :laughing:
E
evan9162
Boise, ID
Now I'm just trying to figure out how to get some silver polish in there...
Christoph
Christoph
Hagerstown,Md
Evan
I have been wondering about that.I have a ARC4+ with a lot of hours on it that looks just like your led.
C
Similar threads
Lantern32
Replies
5
Views
2K
nbp
H
Replies
64
Views
7K
The_LED_Museum
The_LED_Museum
nathan310
  • Locked
Replies
3
Views
1K
B@rt
steve_vance
Replies
8
Views
1K
BIGIRON
BIGIRON
