my Maglite Solitaire LED mod
Turbo_E
Turbo_E
BTW testrips, i used the meathod in your link and it fries LEDS. i dunno about Nicha LEDs but mine went up in smoke.
be warned.
Pila_Power
Pila_Power
Perth Australia
Wow!!! Thanks for going to all that effort Turbo_E! /ubbthreads/images/graemlins/smile.gif
Seriously, it must have taken SECONDS to slap that together! /ubbthreads/images/graemlins/wink.gif Just kidding, I feel bad that I kinda made you go to the trouble to draw stuff for me, thanks /ubbthreads/images/graemlins/smile.gif
Honestly, thank you.
*print*
*hunt down my Soli*
K
kevino
Can anyone tell me where I can purchase the rechargeable lithium ion AAA 3.6v battery?
also i'm going to use a 10 mm led on my solitaire. What kind of resistor should i use? if I use a higher rated resistor does that mean lower light but longer battery life?
thanks.
D
davidefromitaly
43.66 N - 13.13 E
AW have li-ion AAA
and yes with a higher resistance you have less light but more runtime
why you want to use a 10mm led? how many mcd output and at how large spot?
K
kevino
the specs on the led are
EMITTED COLOR : WHITE
SIZE (MM) : 10 MM
LENS COLOR : WATER CLEAR
MATERIAL : INGaN
LUMEN : 13
just figured the bigger led, the more light. I'm new at this flashlight stuff so if i'm wrong, please correct me. I understand battery life will suffer with such a large led, but hopefully i can aquire the lithium AAA battery. Any other suggestions?
-Kevin
Bimmerboy
Bimmerboy
Long Island, NY
Excellent thread. Too bad I just came across it a few minutes too late. I just ruined a brand new MJLED with a 14500 Li-On AA in a cut down single cell Minimag, and no resistor. Yes, I feel rather retarded now. It looked great for about 6 seconds, then quickly started dimming and turning a strange greenish blue color. Panicked, and started turning the head the wrong way, which delayed shutting it off. Now it's permanently tinted green and not as bright as fresh out of the bag (I just tested it with 2 fresh alky AA's, which I believe provides the proper voltage and current with no resistor).
I only bought two of these because I wanted to do two mods, and now I'm down to one. That's what I get for trying to save money. I'd really like to put the remaining good one into a Solitaire, but have some questions first:
A) I'm not clear on how to hook a resistor into the tailcap. Could someone describe how or point me to the info?
B) What's the brightest combination of battery and resistor in a Solitaire while staying in a safe range for the emitter?
C) If I can get another MJLED for that second mod, does anyone know what resistor to use for a 14500?
Man, screwing up that nice LED put a damper on my evening. I'm gonna' go make a new thread in the LED forum and whine about it there.
Turbo_E
Turbo_E
if it makes you feel better I smoked my LED too. i dont see how a LED has enough resistance to drop 12V down to 3 or so V.
Anglepoise
Anglepoise
Pacific Northwest
The trick is the 12 volt battery , MN23.
Now in the posts ^^^^^, we seem to be talking about two separate batteries.
If you use a MN 23, 12 volt battery, you can dispense with the resistor because of the very high internal resistance peculiar to this one battery.
You can get a 23,000 mcd LED and stick it in the Solitaire and using a MN 23 12 volt battery, and a longer spring in the tail cap and no resistor.
The output is excellent, but continuous run time is not good but intermitant gives the battery time to recover. Fun , cheap mod.
Turbo_E
Turbo_E
ahhhh...i assumed it was a regular 12 from a car alarm pager.
F
Flashlike
Champlin, MN
Turbo E--
In your original post with your instructions for modding the Solitaire your said in step number 4:
[ QUOTE ]
4. get a 12V A23 battery or similar. Make a dummy spacer with a resistor. I used a 470 ohm -1/4 W resistor (100 ohm is also safe, but your battery and LED will die faster i imagine, although mine hasn't)...
[/ QUOTE ]
In the follow up post you said [ QUOTE ]
EDIT 100 ohm seems to work way better--so bright..it hurts
[/ QUOTE ]
Then in another post you said [ QUOTE ]
if it makes you feel better I smoked my LED too . i dont see how a LED has enough resistance to drop 12V down to 3 or so V.
[/ QUOTE ]
I have a Mag Solitaire that I'd like to outfit with a 5mm LED. I have a 100ma I.S.P. 5mm LED made in Korea. But I really don't want to "smoke" it like you smoked yours!!
Does anyone know how to make it work with the 12V A23 battery without toasting the LED? /ubbthreads/images/graemlins/help.gif
Turbo_E
Turbo_E
nono, i smoked one when i tried to power the LEd without ANY resistor. 100 ohm is perfect IMO. You're welcome to try a little lower like 75-80 ohm but i never tried so don't blame me if your LED goes *Poof*
my instructions with the hurting diagram works fine.
F
Flashlike
Champlin, MN
Turbo_E--
Thanks for the clarification. I'm going to try the 100 ohm 1/4 watt resistor, too. Maybe I can pick one up at a Radio Shack store.
You said in your original post that you used an "A23" 12 volt battery.
But AngelPoise said [ QUOTE ]
[/ QUOTE ]
I'm confused. /ubbthreads/images/graemlins/confused.gif
Isn't the A23 Eveready's version and the MN21/23 Duracell's version of the same battery?
Anyhow, I think that you're better off to go with a resistor because of the 12 volts.
I'm going to epoxy the back side and "neck" of the reflector (except for the opening, of course), then drill it out slightly after the epoxy cures to accomodate the 5mm LED. Otherwise I think the reflector would be weakened too much.
It's a lot of fooling around, but the end product will be worth it if it's done right!
This comment is a bit off-topic, but I've done this mod on a little Streamlight KeyMate flashlight:
SL KeyMate Mod.
It involves quite a bit because you have to press out the reflector, resolder the replacement LED, etc. But WOW what an impressive light it is after it is done!
Turbo_E
Turbo_E
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
i couldnt tell you, but i do know blowing expensive LEDs isnt cool. use a resistor first. I think the a23 is a more common battery.
anyways I have 2 premodded Solitaires if anyone wants to take em off my hands for $20 shipped? one blue and one gunmetal/silver. I also have a bunch of "resistor/spacers" + 20,000 MCD LEDS for $6 shipped if you want to mod the reflector yourself.
Pila_Power
Pila_Power
Perth Australia
My LED holder part disintegrated /ubbthreads/images/graemlins/frown.gif
It was very old but it's going to a much better home on mondat - into AWR's workshop!!
I have a feeling he's going to get the honor of being a subject in one of Andrews new ideas /ubbthreads/images/graemlins/smile.gif
Anyone ever make or buy a glass lens for the soli?
I 'dented' mine from the inside by screwing the head on too tightly with a 5mm LED in there which sits up too high.
Similar threads
F
Replies
21
Views
18K
ampdude
A
T
Replies
2
Views
2K
DM51
Everett
Replies
3
Views
926
Everett
Everett
S
Replies
16
Views
27K
Icarus
Icarus
sed6
Replies
24
Views
13K
ruriimasu
ruriimasu
