Re: RUN AWAY FROM THIS LATHE!
As frustrating as this has been for you, there are some points you may want to keep in mind ...
Every piece had been hit bent or paint scraped off ... Both cabinets are bent and smashed ...
It is
always the customers responsibility to inspect a freight shipment, whether that shipment is a lathe or a bag of Styrofoam packing peanuts. If the customer does not inspect each & every carton in the shipment, and signs the Bill of Lading, the trucking company is no longer responsible for any damage that they've done - much like giving the freight line a Get Out Of Jail Free card.
Had you inspected each carton, the damage should have been easy to spot. Bent and smashed cabinets never arrive in pristine shipping cartons. Had you reported the damage to the driver, or refused to accept the shipment, the freight line would have been responsible. Since you did neither, it's now your responsibility (not Matt's) to fix the damage. Tough way to learn a lesson.
I ordered leveling feet from him this should help me level it and it really should come with them anyhow
There isn't a lathe sold today or in years past that comes with leveling feet. Used lathes sometimes do. Leveling feet are provided by the owner of the machine.
I will never again buy a machine off the internet without looking at it.
Even looking at a lathe & running it under power is no guarantee that there will be no problems. To get a problem free lathe in the year 2011 means paying a minimum of $20,000 or more. There are ready to run machines from the USA & Eastern Europe that are plug-n-play, but they cost ten times more than a similar size Chinese machine.
Here's one example ... my Chinese 14x40 heavy costs $11,950 (with taper attachment, DRO, & 5C collet chuck) plus truck freight. Fit & finish aren't terrible, but certainly nothing to write home about. Before starting the boring & reaming of flash lights, the alignment of the tailstock was checked - thank Goodness. Left-to-right alignment was dead on, which is no surprise since the set over is easily adjusted by even the lowest skilled Chinese worker. BUT the tailstock sat .010" low. No big deal, just five miserable hours of milling, grinding, scraping & shimming to correct a major defect that should have never passed quality control. The inside surfaces of the TS looked like they had been ground with a brick. All this on a machine costing nearly $12k.
Chinese machines, whether from Matt or Enco or Grizzly, will need some amount of work. Figure 40 hours more or less, normally done a few hours at a time as issues arise. Not much way around this, other than spending $20k or more.
Don't give up. You'll learn a lot about your machine as you work through each small problem. After a while, it will run the way you want it to & turn out nice work. It's a process that we all go through.
