Your "extension cord" is wired backwards but it won't effect the rotation of the motor in single phase AC. If it were 3 phase (3 hots) then changing any two of the three will change rotation of the motor due to the phase relationship of 3 phase AC.
Cool, thanks, makes sense about the rotation being OK.
Since you are using an "extension cord" you probably should change the red and black to eleminate future confusion. No it is not code but I understand your concern about the 220V on the floor and being ablt to disconnect. Have you considered running conduit from the panel to the ceiling above the lathe with twist lock drop cord?
I did, but the assistant at the electronics section gave me a weird/bad look when I mentioned it, so I decided to consider this for later, until I can find out better if/how I can do it in a residential environment.
Are there 3 conductors coming from the new machine or 4?
Just 3. The two hots and the return. At the lathe's electrical box, they tied the return to the earth ground - this is the common ground for everything.
The neutral (white) should not be connected to the ground (green) at the machine or any where outside of the power panel on the side of the house.
What you want to avoid is connecting the white and green outside of the panel. It is a safety issue should you ever get the wrong combination of loose connections it could be a killer. This is not very likely but using an extension cord does increase the risk.
This is how things are wired right now:
1) The female 220V outlet is grounded (green wire) to the metal base of the lathe by 5 metal screws - a solid ground.
2) The electrical panel of the lathe has the return wired as the earth ground for the machine. So by the metal-to-metal bolts in the machine, the earth ground from the female outlet is already "wired" to the return wire in the 3-conductor wire coming out of the lathe's distribution panel.
3) Since I wanted a "stronger" ground from the female outlet to the lathe's distribution box, I shorted the green and the white at the male plug that I created for the lathe, so when it plugs into the female outlet, I have an extra solid connection between earth ground and the metal and the distribution box.
This give me an extra path to earth ground, so now I don't have to count on the metal-to-metal connectivity to make sure the lathe's electrical panel, and of course the lathe, are at earth potential. If by some means one or both of the hot wires were to contact the metal on the machine (the parts I would touch during normal operation), the way I have it wired now would allow for an extra path to earth ground, which lowers the chance of me being shocked.
Now, I must admit that I am still fuzzy on the increase risk part by having the extra ground tied to the return at the lathe. Please note that I am not claiming to be an expert, I am not an electrician, and I do really want to understand this better, but I still don't follow why the way I have it wired now is more dangerous than not connecting earth ground. Can you please expand on this some more? Is there an alternate way to wire it so that it would be even better, safer? I though about adding a single thick wire from the earth ground in the lathe's electrical box to the metal base of the lathe, which is at earth potential - is that better perhaps?
If your lathe has only three conductors 2 Hot and a Neutral (wh) you should probably change out the lead to 3 conductor with ground and connect the ground to a substantial chassis ground in the machine.
Per the wiring diagram of the lathe, and by looking at the wiring panel on the lathe, there is a 24V step down transformer, but nothing for 110V. Still, the lamp, and the coolant pump run on 110V, so (and I have to double check) they might just be running one of the hot wires and the return to run those.
I thought the same thing when I saw the wire size, but then I thought about how he is using it "On the floor" and the extra heavy wire might be a good thing.
That big wire sure is expensive though!
That is exactly why I got the wire I got. Extra thick and water resistant. Although it is going to be on the floor only while I run the lathe, I wanted to be extra careful. The wire alone was $44 at my local Home Depot.
Wondering if your lathes gearbox lets you dial up the different thread cutting feed rates without removing/swapping change gears?
And do you know if the grizzly you were considering does?
Yes, I tried it a little bit last night. You can change threads on the machine by using the round dials without having the change physical gears on the machine. I believe the Grizzly allows for the same, but my gears are completely enclosed on its own fluid bath, which is a great thing for wear and noise
Will
