Dr.K
I have been running rechargeables. I did a batt change last night.
Everything was working correctly, except for high.
When I switched to the high level, it came on bright for about one second, then ramped down (like when the battery is dying)
I tried 3 different cells, all with the same result. I tried some batt detect resets, a factory reset, changed some of the programming and levels, but still got this same result.
All batts tested good 3.7-3.8 volts. I was left scratching my head.
For kicks & shittles I dropped in a primary 123, and did another detect reset.
It worked fine!!
I did another batt detect reset and put in the RCR123, and now it works fine also.
Just thought I would share my quirky little adventure on new years eve.
It worked fine!!
