I just got my rexlight in today and popped in an alkaline battery. It turned on right away initially and was very bright. I cycled through the modes and thought "wow, this little thing is cool!" I messed around with it for about 30 seconds the first time it turned on.
I fully depressed the switch and the light turned off. I pressed it again and it did not turn back on....at least, right away. I put it in my pocket and about 2 minutes later, I took it out and the light was on. I turned it off and tried again, but now it just won't turn on anymore no matter what I do. I tried several different fresh alkaline batteries-none worked. I separated the tubes and examined them-I saw nothing that looked out of the ordinary to me. I started searching this forums and found a post with someone having a problem similar to mine. Someone in that thread suggested that the person take sandpaper and sand the andonized edge of the battery tube. I took all three tubes and sanded each contact edge until the metal was showing and tried again-no luck. I also tried tossing that wavy washer into the light with the battery-again, absolutely nothing.
Can anyone offer any advice? This is the first good light I've ever owned and I have no idea what I'm doing wrong ;(
Is the light defective? If so should I email Kai about it? I don't want to RMA the rex and wait another 2 months to get a replacement if this problem is fixable.
