I used two differant VOM and still reads O volts. Is this normal? If I left the light by mistake could it really go to 0 volts? Should I try charging it or is it garbage.
Interesting I have always wondered just how creative one needs to get in order to "revive" a tripped Li-Ion cell. Anyone care to explain or give some clues. I looked around the forums for awhile now and no luck. Thanks in advance.
The proper way would be to use a bench power supply set at something like 3.2V.
The "creative" way is to string two fresh alkaline AAs in a series and connect them to the LiIon for, say, two seconds or thereabouts.
You might want to use a resistor in series if you're going to use a battery to charge another battery. The internal resistance of the battery might be low and cause an extremely high charging current.
