SUBjohan
After seeing Packhorse's thread about the W200 I thought I'd buy one from DX.
First impression was verry good, nice build. Put in the battery's and see what happens, hmmmmz constant flickering.
So this one should be modded I am thinking Cree XR-E R2 with a 1400mA AMC (single mode driver) driven by 3 eneloops.
So lets make this thread a step by step thread, due to the fact that I am rebuilding my house as well, it is probaly going to take me some time :mecry:
So first lets open one, this is very easy.
Lets start on the battery tube side:
Looking inside the batery tube
Just take a needle-nose pliers and pull out the alu tube:
Here you can see the O-ring which camps the tube inside the housing:
And there it all is:
First thoughts:
-Spring should be mounted fixed to the tube
-Tube should be better fixed inside the housing
Next is the head:
Start with removing the large O-ring:
So the big O-ring is out:
Get those needle-nose pliers out again:
There is the heatsink, also fixed with a O-ring
Here you can carefully press out the front glass:
So there youve got it all:
Next is the led pill it self:
The led pill:
The empty head:
The inside of the led pill:
The porely mounted led (not fixed to the heatsink):
The led lose from the heatsink:
Overall shot:
Next is the search for the driver:
Surprise there is NO driver!!
So the plan for now is:
-Fix the spring to the battery tube and fixate the tube better in the housing
-Cut down the led pill so I can mount a driver (probably a AMC 1400mA)
-Make a heatsink on my lathe
-Replace the old P4 with a R2 bin led :twothumbs
-Replace all O-rings with better quality ones
Here a small (and verry fast) drawing of my to be made custom heatsink:
To be continued:
Greetz Johan
First thoughts:
Next is the head:
The led pill:
The empty head:
Overall shot:
To be continued:
Greetz Johan
