Spacemarine
This is the charger I bought from AW here:
Linkt to B/S/T non flashlights
Shipping from Hongkong to Germany took about 5 days and the charger and the four batteries arrived safely and without any problems.
So far, I've tested the charger with two of the R123a batteries I also got from AW. Without any battery installed, the voltage of the charger is 4.25V.
An empty cell (discharged to 3V) is charged with a current of 150mA and the charger gets noticably warm while doing that. Measuring the current a few times while charging indicates that the current drops steadily the whole time until it is around 15 mA when the LED turns green. The voltage is around 4.09V then.
If you leave the cell in the charger after the LED turned green, the charger will continue to charge, but the current gets very low because of the high voltage of the cell.
Approx. 8 hours after the LED turned green, the cell is at 4.20V and is still charged with a current of about 2mA.
I also discharged two of these cells with 0.2A down to 3V in my X-Peak 3 charger which has a display and can show me the discharged capacity. A cell which I took off the charger the moment the LED turned green had a capacity of 595 mAh (about 3-4 hours charging time. After a few more cycles, I got about 680 mAh out of a cell which was charged up to 4.2V (about 10-12 hours charging time)
I think 680 mAh is ok for a 700 mAh battery, the remaining 20 mAh could very well be a inaccuracy of my charger.
Here are bigger versions of the pictures:
backside
frontside
top
On the pictures you can see some tape wrapped around the charger, that is because I opened the charger and since it is only glued and not screwed, I wasn't able to close properly.
The big "1" on the first picture is also made by me to distinguish the cells, so yours won't have that.
Conclusion on charger:
Very nice and small charger, in my opinion worth the price. The only drawback for me is that I need an adaptor to plug it into my wall, and that is it doesen't have a cut off ability, although this feature is advertised on the packaging.
So if you have the time to charge your batteries over night and don't forget to unplug them the next day, you will find this charger very useful.
backside
frontside
top
