Lightfoot98
I need some help here.
I have one of these:
http://www.miraclebeam.com/item_display.asp?pid=2622&cid=3
Nice light for what I paid for it, $5 on clearance.
The die (emitter) in the star has a busted lens dome.
Would like to fix this thing, but I'm having trouble finding
a 1watt die (emitter) or star with led on it.
Star dia. is 20mm
I don't see any kind of controler chip anywhere, just a wire
from the center spring (+) arround to one of the + (pos) pads,
and a bare stiff wire from under the edge of the star bent over
making contact to the tube for the neg (-), then bends arround and is
soldered to a - (neg) pad on star.
2Xcr123 drives this.
I guess this is a direct drive running on 6v???
Nothing in tailcap but a 8.5ohm resistor.
The star has PROLIGHT in one edge on one point of the star.
looks like a standard 2 contact off-set leg die (emitter).
Any help would be appreciated.
Star dia. is 20mm
