Juggernaut
Ok what is the cheapest soft starter I can buy, it needs to handle up to 21 volts and 61 amps, it's size is really not important, obviously it's not going into a Maglite……
it needs to handle....61 amps....obviously it's not going into a Maglite……
OK,I give up,what are you building-a lighthouse???LOL
I know little about electronic resistance, so a little walk through would be appreciated. How do I set up these 1-ohm NTCs? Do I run them in series, parallel, 2, 3, 4+ of them? .....I want as little resistance while running as possible since the 18 rated volts of the battery pack is what I'm going for if it ends up closer to 17.5 or something I can live with that but not much less. From this 18 volts I be pulling somewhere around 61 amps.
