Need a small transformer
markc987
We had a weekend of high winds with down trees and power surges. One victim was my builtin vacuum cleaner transformer. I found it smoking away and was able to shut things down before and real damage was done.
However we now have no vacuum. Everything seems fine excepting the transformer is burned up. It is no longer available from Sears. The motor is
a lamb 115334 which has these specs-
L-115334 7.2BPT, 2STG, B/B, 120V, 1450W, 13.0Amps
Anyone have any idea how I could match one up? The label on the transformer itself burned.
I can only see two potential uses of the low-voltage: 1) powered attachments, 2) the main motor's relay.
The vacuum must have #2, so see if you can find any part numbers or specs on that part.
