Need advice for best light for this situation
jefffoxsr
I would like something larger for use at the house in power outage situations that will have a good compromise between runtime and lumens. We've had power outages that have lasted over 7 days.
Regulated would be nice.
I have the Streamlight Propolymer 3C 10 LED. It has a long run time, but it's not very bright. I estimate 30 lumens.
I like the Inova lights, but the runtime is way too short.
Over 100 lumens would be nice.
Thanks for the education.
jefffoxsr;
The best solution to your light question would be a high efficiency LED like a Cree P4 or Q series.
Then you would have to operate it at a lower current level to get the efficiency over 100 lumens/watt. At 50 lumens you would only need 1/2 watt.
Power source would have to be lithium ion batteries for best power density. I would suggest two or more #18650 in parallel for the longest run time. To get days of run time, it would have to be a pack of lithium cells.
It would have to be a custom-built light to get all the characteristics you want.
But it is an interesting idea....
Larry Cobb
Hello jefffoxsr and welcome to CPF🙂
More than 100 Lumens output with a runtime for days,hmmmm...........these requests are not playing well together.🙂
Stay a while here and you'll have a light collection which lasts for days:grin2:.
Get a few spare cells, primaries and recheargeables (with 12V car-adaptor) and take a look to the lights which you'll really like.
Different brightness levels are a great advantage looking for long runtime.
Best regards
____
Tom
____
Tom
At least he didnt ask for AA Maglite size 😀
100lumens with 7 days(170h) runtime is possible but bit bulky.. 2 or 3 XR-E leds running at total ~1W, powered by 22 pcs of 18650 2600mah cell or 12pcs D-cell alkalines. 🙂 With 56 hours runtime battery pack size would be more reasonable, for example 4D maglite could work as a case donor for this project.
Anyways I would recommend 12v powered battery charger and enough big lead-acid battery or even full-blown emergency power system.
huntlight FT-01 XSE-cree
would be fine. works on 18500 and CR123. many stages.
I'm not sure where you live, but here it's only dark for ~12 hours a day on average. And, I tend to sleep for about 7-8 of those hours. So, 7 days really only equals about 35hrs assuming you leave the light on constantly when it's dark and you're not sleeping. I can't see needing >100 lumen the whole time, so I'll suggest something like a Fenix L2D-CE. 55 hours on low (9 lumen) and the ability to go to 135 lumen (for 2.4 hours) when needed.
for 100 lumens running for 7 days, your best bet is having packs of spare lithium primaries, running multi Cree-xre's at lower level for best efficiency
Are you another nocturnal Artic Circle user? :sssh:
If the OP doesn't sleep, and lives north of the Arctic Circle, I could see that 7 days would equal 170+ hours otherwise I don't understand your answers.
I couldn't agree more with you Stereodude (if that is your real name 🙂
The F2D-CE is what I bought for my bug-out-bag (emergency kit).
I also threw a Gerber Ultra Infinity-M in there. It's not super bright, but when you are in pitch black, it's good enought to read by when it's pointed on a white ceiling. Plus, it runs for like 25 hours on 1 AA.
Depends on what you want the lights for. My tri-LED Modamag will run on low for at least 48 hours and gets *real* bright.
A few LEDs and a 12 volt battery will last a very long time for good light.
The best solution I found, based on over a year without power 98% of teh time is to go to bed soon after dark and get up as it gets light.
jefffoxsr said:
I would like something larger for use at the house ..
I use a 90 Ah lead acid battery and a flourescent tube with 12 V ballast for this sort of situation. Add a few solar panels and you will be going forever.
"Portable" is not a requirement, as I understand.
You guys made some good points. Thanks for the help.
I already have a Fenix L2D-CE, so I must be in good shape.
If we are talking power outage and dark, one does not need a tremedous amount of light in the dark.
Why not a long running light like the SL3AA 10LED and a brighter second light.
I still can't see what 100 lumens is good for if there is no natural light.
A M*gled running on 2D is supposed to run 20+ hours, and it makes a pretty decent amout of light.
well, on _average_ its dark 12h no matter where you live. 🙂
On polar areas it is just 180days on and 180days off, still daily average of 12h :laughing:
I dont know where Jeff is living, but he was asking for a 1 week runtime 😗
I live about 100miles south of polar circle, and we already have plentiful 8 hours of daylight in this time of year.
Not exactly... He said they've had power outages that lasted 7 days. That's not 7 days of runtime.
Martin said:
= 29 min of power per day. What was the voltage when the power was on ? Where was that ?
More like on for an hour or two once a week or less when "company" came in.
First six months or so at Rancho El Barrill and the last 7 months at Punta San Francisco on the Baja Pennsula.
There really is no need for that much brightness in a power outage. A headlamp and a low level lantern are the best tools for such a situation indoors. Low lumen lights to navigate hallways and take away from the "stuck in the dark" feeling, and a headlamp for reading, knitting, whittling or whatever you do without a computer to navigate CPF. For outdoors, you’ll be surprised how well any of your mid level lights throw when there are no street lights on. Even a single 5mm led throws three times farther and I swear my surefire E1L outdoorsman threw 200 meters to light up the apartment complex down the street.
I had a power outage last Friday night ,..the power outage was my fault, I forgot to pay my bill..:ohgeez: Most used light was a couple of tap lights , a cheap headlamp and my Streamlight Twintask....You dont really need a scorching flashlight unless you are going to use it to cook..:grin2:
I tried to see how long they will last but I got tired of waiting , so I just went to sleep....:laughing:
