Nice..
Above Eamon posted 10 degree FWHM for the 225 and cutter is calling for 5.
What is it closer to?
~G
According the PO datasheet, it's a +/-5deg reflector. Five degrees to either side of on-axis is 10deg. If you look at the intensity graphs, the 50% point is ~5deg to either side: Full width half measure.
It's one of those areas where terminology counts. Cutter calls their narrow XR-E(3) optic a 4deg optic, but it's a +/- number. The actual beam spread is 8 degrees. I prefer to use the actual beam spread, derived from manufacturers' data. I do wish that the manufacturers would collaborate and unify the terminology.
http://www.polymer-optics.co.uk/products LED optics cree.html
Note that Ledil refers to +/-8deg for the EVA.
http://www.ledil.fi/datasheets/DataSheet_Eva.pdf
But Fraen does not, although they do tell you that divergence is measured
FWHM.
http://www.fraensrl.com/images/Fraen-FRC-MCE-datasheet.pdf
Eamon
