AvroArrow
I need some advice on building a regulated M*g 3D light. I know that it seems contrary to all the 3-cell direct drive mods that everyone's doing, but I'd like a regulated light that'll run for more than just 1-2 hrs at full brightness. Just another note, I'm using a 3D host because I already have 3 of them and they are cheap and plentiful around here (a mini-M*g 2AA & 3D combo package cost $28+tax CAD (~$22US) at Costco here). 4 or 6 cell C/D bodies (I don't think I've seen any 2-cell bodies) cost considerably more and are only available at a few specialty shops (otherwise I would have already bought a 2 or 4 cell and used a BB or DB driver). I'm also working with TV1K & TX0K Lux3s (although I do have 2 L-bins now).
Here's my goal for this 3D build:
- current regulated at 700-750mA
- be cheap to run (read: Alkalines, and I know NiMHs are cheaper in the long run, but it's got higher initial cost)
- run on K-bin Vf LuxIIIs
- minimize costs
So far the only viable solution is to use a Wiz2 buck/boost convertor set for 750mA. I'm sure it's a great circuit, but it's not exactly cheap ($30.25+S/H). The cost of the Wiz2 alone almost equals the cost of LuxIII + O-sink + 3D body. Are there any cheaper alternative drivers that I could use?
I was initially thinking of using a Fatman or BB driver to just boost it when the voltage dropped and hoping that those drivers would just run in direct drive mode when Vin>Vout, but when I actually read up on both drivers, it looks like I might smoke the driver & the Lux3 instead if I fed them too much voltage. Then I checked the Nexgen which has an overdrive limit of 0.7V which was better, but when I measured the voltage off 3 fresh alkalines, it was like 4.65V, quite a bit over 3.51-3.75V Vf of a k-bin. And the Nexgen was only $2 cheaper than a Wiz2, so I might as well get the Wiz2 and not worry about the Vf or batteries. But I'm back at the cost issue again. Is there no economical way to build this up?
As a side note, anyone know of a good way to remove an Arctic Alumina epoxied emitter from an O-sink without killing the emitter? (I already AA'd 2 of my k-bins without really thinking) I was thinking of freezing it for a couple hours and try to pry it off with a screwdriver (seems to work for epoxied heatsinks on video card GPUs). I might just swap my K-bins out (save 'em for something else) for L-bins and DD it if there's no economical way to regulate them.
*Edited to reduce current requirement and added cheap to run.
- minimize costs
