Need advise on most efficient CR123a light
Kamerat
Norway
I love the size and power of 1 X CR123a lights. However, I've found that I very often only need 30-80 lumens indoors and that it would be very nice to find the most efficient light for this purpose. XP-G2 / XM-L2 can both be good I guess - but I don't know which is the most efficient for indoor use.
Edit: I'm looking for THE most efficient CR123a light out there when pushing 50 lumens.
I've tried to use the checklist:
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__X__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
____Up to $25.
____Up to $50.
____Up to $100.
_X___Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
_X___I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
_X___TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
__X__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__X__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
__X__I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
__X__I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
__X__I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
__X__I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
__X__I want an indoor "blackout" light (15-50 lumens)
__X__I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
__X__Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
____Less than 1 yard/meter (reading, other close work)
_X___Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I am searching from a helicopter)
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
__X__3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
__X__Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
__X__I want a forward clicky (Helpful for momentary activation and signaling).
__X__I want a reverse clicky (For use with multi-mode/level lights).
__X__I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
____A simple on-off with only one output level is fine for me.
__X__I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
__X__I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ---...--- emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
_X___I don't care - BUT I LIKE Ti.
____I don't know.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
__X__IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
__X__In house (temperature/climate controlled environment)
__X__Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_________________________________________ ____
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
NoNotAgain
Blue Ridge Mountains, VA
Lots of lights meet your requirements, but the one and only single CR123a light that I own is a Led Lenser F1. It's 3 inches long, has a pocket retainer clip, two light settings (400 and 60 lumens) and a strobe feature. As found on a popular auction site, you can expect to pay $70 or so.
It's one of my EDC lights. Runtime averages close to two hours on high and 4 hours on low. Not bad for a light the size of a roll on mints.
Kamerat
Norway
Thank you for the reply! I'm using a HDS 120 hi-cri now, and really enjoy the fact that I can use lower settings for longer runtime. Would also be great to have more that 4 hours with 60 lumens on a cr123a. Looking for a more efficient light :)
Kamerat
Norway
Impressive! Exactly the type of answer I am looking for. Is there any light with longer runtime at around 50 lumens than the Fenix PD22?
välineurheilija
Finland
Two hours on 400 lumens that WOULD be great but look at the runtime graph here.
http://www.led-resource.com/2013/04/led-lenser-f1-review/
Kamerat
Norway
I just saw that the Fenix PD22 do not accept rechargeable batteries, that is a deal breaker for me and my wallet.
Kamerat
Norway
Thank you, I looked at the review here on CPF and it says 4 hours and 55 min at around 50 lumens with the XM-L2 version. Very interesting.
BTW, I have the D25Cvn - a totally different animal with all guts, no runtime! I great light for its purpose.
jabe1
Cleveland,Oh
I think the Fenix can use RCR, just not officially, and may lose low mode.
Zebralight SC30/31 would work I think. If you could find one.
Even the Thrunite Neutron 1C does pretty well.
NoNotAgain
I guess that the real world doesn't mean a lot to the reviewer of led-resource. Not saying that the review is bad, just it's not how I use this light.
My use has been a couple of minutes at a time, then the light has been turned off. I don't know if I would use the light at 400 lumens for two hours straight as it wasn't designed for this use. I have used the light for a series of five minutes on then ten or more minutes off to test out the battery life. I haven't seen the regulation kick in on the five minute stints.
I've got lot of different lights,and one of my EDC lights wouldn't be used constantly for hours on end.
A previous manager of mine asked why did I need such a large light referring to my 6D cell MAG light with a Terra-lux LED conversion (it stood on end beside my desk). I said that the light was for my use and asked why was he interested (a non-flashaholic)? Same guy would frequently ask to borrow a screw driver or an adjustable wrench. Two weeks later we had an earthquake, the emergency lights failed, and I was the only one that had a light to see to exit the building from my work area.
reppans
Just some thoughts from a sub-/low- lumen efficiency guy collecting in the AA/14500 market. I have a light box and occasional test my light side-by-side for efficiency (lumen-hours).
- Careful comparing spec sheet marketing hype - ANSI rules are wide enough to drive a truck through. The lumen-hours difference between conservative and exaggerating manufacturers can be ~2x in specs, for more-or-less equivalent performance. If you go with a reputable name, and current-regulated clicky/twisty, I think you'll find actually performance a lot closer than what the specs might say, so I'd personally just go with the light with the best features for YOU. At a minimum, compare Selfbuilt's output/runtime graphs for BOTH lights (or near equivalent as this gives a sense of manufacturer conservatism/exaggeration).
- Not sure if you're married to the 16340 format but I'd suggest considering the 14500 cell too which has ~25+% more capacity, and has the option of 2500 mah Eneloops (also a lot more energy than a 16340). 3V CRAAs are available for $1.50 (equiv. to a CR123) if you want Lithium primaries. And, in a pinch, you can buy cells in any gas station or cannibalize from another device - for me, that represents a lot of emergency runtime.
välineurheilija
Finland
Yeah true but i was just pointing out that with clever marketing everything isnt allways what it seems most of us on the forums know rightaway that there is a catch in those runtimes but there are people out there wondering how dim a 400 lumen light is after its been on for 15 minutes :)
