renegade_riot
- Joined
- Jan 10, 2010
- Messages
- 2
I'm looking for a light that is under $40, under $30 would be better, that i can use rabbit hunting on my farm. I don't know if i would need a projection light or not for this, i don't want the beam to be too narrow that i can't hold the light on them.
i was looking at dealextreme and bestofferbuy for cheap lights.
I ordered this one, but it was out of stock so looking for suggestions
1 x WF-800 3W Cree Q2 LED Flashlight (2x18650 4xCR123A 7.4V~17V) (E2267)
I already ordered two 18650 batteries so the light would need to run on one or two of those, and i'd prefer a clicky on the tail over twist.
i didn't know if lights like this were trustworthy or not
http://www.bestofferbuy.com/trustfi...led-flashlight-with-strap-118650-p-13159.html
http://www.bestofferbuy.com/spiderf...ashlight-with-clip-2cr123a118650-p-13191.html
so what would you guys suggest? thanks
0) What Region/Country/State will the light be purchased in?
____I will be mail-ordering or buying online, so this doesn't matter.
_xxx_I am in North America. More precisely I am in ___iowa____________.
____I am in South America. More precisely I am in _______________.
____I am in Europe. More precisely I am in _______________.
____I am in the Middle East. More precisely I am in _______________.
____I am in Africa. More precisely I am in _______________.
____I am in Asia, Japan or Micronesia. More precisely I am in _______________.
____I am in Australia. More precisely I am in _______________.
1) Price Range: An easy question, but you may change your mind after answering the rest!
____I only want to pay $1-10.
__x__I can spend $15-30.
____I could spend $40-60.
____I am willing to spend $80-$120.
____I have no limit!
2) Format:
__x__I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a portable spotlight.
3) Length:
____I don't care.
____1-2 inches. (Keychain sized)
__x__2-4 inches. (Pocket carry)
__x__4-9 inches. (Holster carry)
4) Width:
__x__I don't care.
____I prefer a long narrow light.
____I prefer a short wide light.
5) What batteries do you want to use? Alkaline batteries are easier to find and less expensive but don't pack as much stored energy and are don't work well in cold temperatures. Lithium batteries have long shelf life (10+ years, great for stored emergency lights) and are not as affected by cold but must be kept dry and are more expensive. Rechargeable start expensive, but if used frequently pay off quickly.
____I want common Alkaline batteries. (AA, AAA, C, D)
____I want lithium batteries. (coin cells, CR123, AAA, AA...)
__x_18650_I want a rechargeable system. (an investment, but best for everyday use)
6) How much light do you want? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to read a map, or find a light switch, in a dark room. (5-10 lumens)
____I want to walk around a generally paved area. (15-20 lumens)
____I want to walk unpaved trails. (40 lumens)
__x__I want to do Caving or Search & Rescue operations. (60+ lumens)
__x__I want to light an entire campground or dazzle an intruder. (100+ lumens)
7) Throw vs Flood: Which do you prefer, lights that flood an area with a wide beam, or lights that "throw" with a tightly focused beam? Place an "X" on the line below.
Throw (distance)----------x------------|----------------------Flood/close-up
8) Runtime: Not over-inflated manufacturer runtime claims (like some LED lights). but usable brightness measured from first activation to 50% with new batteries.
____20 min. (I want the brightest light for brief periods)
__x__60-240 min. (1-2 hours)
__x__240-360 min. (4-6 hours)
____360+ min. (More than 6 hours)
9) Durability: Generally the old phrase "you get what you pay for" is very accurate for flashlights.
____Not Important (A "night-stand" light.)
__x__Slightly Important (Walks around the neighborhood.)
__x__Very Important (Camping, Backpacking, Car Glove-box.)
____Critical (Police, Fire, Search & Rescue, Self-defense, Survival.)
8) Switch Type:
____I don't care.
____I want a sliding switch. (Stays on until slid back.)
__x__I want a "clickie" switch. (Stays on until pressed again.)
____I want a momentary switch. (Only stays on while held down.)
9) Switch Location:
____I don't care.
____I want a push or sliding switch on the body near the head.
__x__I want a push switch on the back end of the body.
____I want a rotating head switch.
____I want a rotating end-cap switch.
____I want a remote control.
10) Operational Modes: Check all that apply.
__x__A simple on-off is fine for me.
____I want multiple light levels. (some lights have 5-16 light levels.)
____I want a strobe mode. (blinks to show location.)
____I want a tactical strobe. (Flashes rapidly to disorient an opponent.)
11) Is it important whether the body is metal or plastic/composite?
__x__I don't care.
____I want a metal-bodied light.
____I want a plastic/composite light.
12) Special Needs: Is there anything else you want or need that hasn't been mentioned? Circle any below or write in your own comment(s).
____Red (night vision preserving) filter
____Other filter colors (Amber, Green, Blue, _________)
____Waterproof – how deep: _____________
____Non-reflective/dark finish (stealthy/hard to find)
____Polished silver or brightly colored finish (for easy locating)
____Corrosion resistant or hard-anodized finish
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Built-in second (or spare) lamp or filament
____Belt/Jacket clip
____Holster
____Wrist/Neck Lanyard
____Kobuton/self defense features
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
2) Format:
3) Length:
____I don't care.
4) Width:
__x__I don't care.
8) Switch Type:
____I don't care.
9) Switch Location:
____I don't care.
__x__I don't care.
____Holster
