mobile chernobyl
- Joined
- Mar 21, 2010
- Messages
- 4
I've searched this website and read it pretty thoroughly on information regarding the C2000/C2002 LED array from Bridgelux and it seems most people either power it off CV/CC lab power supplies or TaskLED Buck/Boost power supplies. I'm going to be using a battery I seem to have an abundance of to power this - 11.1v LiPo batteries ranging at 2000mAh and up.
The newer C2002 has slightly better specs than the old C2000 and are as follows:
Vf - 16.2 (14.9-17.5 range)
DC forward Current - 1500-2500 mA
Reccomended to get 2200lm - 16.2 Vf @ 1500mA
So what I'm trying to do is find the most suitable Boost converter for this application, I'm very tempted to just buy a Boost IC and produce a small circuit on a breadboard myself - that is the preferred method because I would be prototyping quite a few of these things if all goes well.
Oh and from all the thread's I've read on the C2000 - none have found a reflector suitable for it yet... well Ledil manufactures them now. They're called the "Brooke" series and come in FWHM angles from 12 to 25 degrees. They are 45mm at the output and could easily be coupled with a 50mm aspherical lens to get some good results :twothumbs
This project is for a stationary light source for riding bicycles at night in a confined area, it is not mobile so the lights weight is not of critical concern. Burn times only need to last about an 1 to 2 hours max at the C2002's 2200 lm rating.
Thanks for any help... this site is very awesome... long time lurker!
