need from help for power led controller
HackoBoy
hi all
i need help from power led controller circuit with microswitch .
When i push one - i have low power
push again - i have medium power
push again - i have maximum power
push again - the power led it`s turn off
Or whether have a circuit with 2 microswitch :
One switch is for this function who i give UP - 1 , 2 , 3 , 4 like succession.
Other switch is for function - but in back succession - 4 , 3 , 2 , 1
for more easy use . :)
Ihave 2 piece luxeon who need from ( 4V / 1A ) each.
and i need from help for battery who use :
Ni-Mh or Li-Ion
i use this Luxeon led for my bicycle .
give me help - pls
"usually" You need
1 Li-Ion, or
3 Ni-Mh
to drive a single led
BUT
You have to use the input voltage Your drivers NEED --> read at explanation
Or are You searching for drivers doing what You type?
possibly You can find something at "flashlights/D.I.Y." at www.dealextreme.com
When You do not have a quality charger for Ni-Mh already, Li-Ion is cheaper.
Li-Ion makes for a smaller light and still packs more power in the same size --> the cell at the moment is a "protected" 18650 Li-Ion
Luxeon Led are a thing of the past, Cree (XR-E) and Seoul (P4 - direct replacement for Luxeon) give double the light at the same power (and make less heat).
PS: You will be lower in cost and better off, not to build a light, but to use existing ones that are surprisingly better than most any "real" bike light in that price class (<100,--).
That were Fenix L2D / LD20 for Ni-Mh batt,
Jetbeam JetIII lights for 18650 Li-Ion batt
add some holder (best one homemade from plastic pipe holders found at electronics section in Your local homeware store)
--> done
