electric sheep
I need a good chargger for enloops and varies AA batteries but have Amazon vouchers i need to spend. Is the Powerex C9000 The best i can get ?
Help Support Candle Power Flashlight Forum
I find no problem with the number of keystrokes. It's very easy and straightforward to follow the menus. It might be a few key presses if you actually count them, but I honestly don't count them. It's just ra-ta-ta-ta...done. It hardly takes more than a couple of seconds.A couple of the Amazon reviewers commented on what they saw as the unusual complexity and high number of button pushes needed to set up 4 batteries to charge (for anything other than the default). Like 48 keystrokes to get a 2A charge on all 4 batts. And no memory to get the same charge cycle the next time, it has to be programmed all over again each time. Would some of you c9000 users care to comment?
I'd recommend one of the 8xx series Maha 8 bay chargers over the C9000. They are much simpler to set up and actually faster at the same charge rate, as they don't have the two hour "top off" charge after 'DONE" that the C9000 has.
95% of the time I'm just topping off AA cells. All I do is snap them in and walk away. The default 1000mA charge is near perfect enough for me to not worry about programming any thing else for AAs. The C9000 does a great job. When I do need to do that occasional programming for a different task, I don't mind the ra-ta-ta-tatting and I think the programming is simple and straight forward for the additional features.I find no problem with the number of keystrokes. It's very easy and straightforward to follow the menus. It might be a few key presses if you actually count them, but I honestly don't count them. It's just ra-ta-ta-ta...done. It hardly takes more than a couple of seconds.
(But you know, if you are the kind of person who can't program a VCR, you don't want a C9000.)
