Turbo DV8
Using your collective wisdom, is there such a light which satisfies most or all of these requirements? This would be my perfect EDC.
1) Cree or SSC, 1AA cell, capable of running on NiMH
2) 2-mode only, please! Low and high, with enough difference between the two to make low truly useful for close-up and/or stealth.
3) Access to modes in following order: LOW-HIGH-OFF
4) Twisty, please. No clicky. I use low brightness 90% of the time. I don't want a clicky that I first have to click through high just to turn it off. A low-high-off twisty would turn onto my most-oft used mode with a twist, then twist off.
5) Low must render a truly significant increase in runtime. PWM is OK, as long as it is a higher frequency than my LOD-CE "psychedelic shroom disco light" when on low or medium.
6) Regulation would be icing on the cake, but I guess not 100% essential with NiMH.
Is there such a light?
