NEED Help!!! Installation guide for McE2S????
toby_pra
Germany
Hello Guys!
I want to change the McClicky Tailcap from my Aleph Tailcap to
a McE2S...i think i have all parts, but dunno how to install!!! :confused:
I owuld need a guide or pics?
Is Someone able to help me????
I put one of these in a few months ago, it wasn't too hard but the details are not fresh in my mind. If no one else has helped you out by the time I get home, I'll take a look at it and let you know how it went in.
Is the McE2S together, or a bunch of little parts and springs?
If it's together, the process is to unscrew the McClicky from the tailcap (pointy needle nose pliers...), take this chance to replace the switch boot if desired (required if you have a "flat-top" McE2S), screw in the plastic bushing with the beveled side of the center hole towards the switch boot (pointy needle nose pliers again...), put a tiny amount of lube on the o-ring on the button end of the McE2S ("flat-top" ignore that step) and push the button firmly up through the hole in the bushing, put the battery spring in the center recess of the McE2S if necessary. Done
