D
**DONOTDELETE**
Guest
FNG,
Since your a mechanic maybe you own some cordless powered Snap-On Tools. If so, then you might look at the new Versa Volt flashlight from your Snap-On man. This light uses the same battery as your cordless drill or impact. The head swivels from straight to 90 degrees. And it has a hook on it to hang from an open hood or something. With the wide base on the bottom, I can crawl under a truck to drop a drive line or something and the light stays put where I sit it while working. I've had mine for about 2 months.
Hope it helps.
Eric
Hope it helps.
Eric
