adirondackdestroyer
- Joined
- Oct 31, 2005
- Messages
- 2,018
I've found with small amount of snow a shovel can push as well as blade (push as in push to a destination, not simply push to the side), but once it exceeds 7 inch or so both will get stuck pusing snow off driveway. Luckily I live on a relative major street so all the snow on street are actually removed within 36 hours of snowing, so I can throw most of it outside and not worry about too much piling up over the winter.
The pusher shovel is much faster than a normal scoop shovel, when it comes to moving snow.
When there is lots of snow it works just as well. You just can't move the snow as far as your normally would (because it starts to pile up).
i just call them all shovels and use what ever i have available.
That's the mindset I used to have, but I knew that there was a better way to do this.
I think "Spencer" was doing it the right way. I picked up one of those large Garant Yukon snow sleighs yesterday from Home Depot in Canada, and I have one of the 36" Garant Pushers coming to the local hardware store on Monday. I tried out the snow sleigh last night and moved some snow back on my lawn. It was so easy I was amazed! It took very little effort at all, and I was able to move a large amount of snow in a short period of time.
I'm thinking that as long as the snow is less 6" or less, then his method is by far the easiest/fastest. You can move all the snow to the side in no time at all with the pusher, and then scoop it all up and put it in a pile on your yard with the sleigh in only a few minutes. This method also means that you don't have the tall mounds of snow on the sides of your driveway, which can block your vision when backing out of your driveway.
