Ogg Vorbis
Hi I'm not too sure if this is the right place to ask this but...
I'm working on my first every Mod making a 5x 3mm LED drop in for the Maglite Solitaire. I thought of it after seeing the mod section on Flashlight review and the use of a single 3mm LED in place of the bulb but i wanted to take it an extra step.
But to the point. I have made the actual drop in and it works really well (except it's rather long and the head doesn't screw all the way down) but i'm using a 12V MN21 battery and a spacer and common sense tells me i need a resistor in there but i'm not sure what i need.
The LED's spec is:
Forward Voltage: < 4.5V
Reverse Current: < 50 uA
Max Power Dissipation Pm = 80mW
Max continuous Forward Current: I(fm) = 30mA
Max Peak Forward Current: I(fp) = 75mA
The 5 LED's are RUNNING IN PARALLEL so i'm not too sure how that effects everything
I'm not that well experienced in the workings of LED's really (I'm only 18!) so i would really appreaciate the help. I will be posting pictures of the end result when i know i can safely run it!
Best Regards!
Danny
The LED's spec is:
Best Regards!
Danny
