Need rechargeable flashlight with LED at 1.5V
conandrum
Hi all,
I have a BRAUN facespa that is currently powered by a little 1.5V motor off of a 1.5V AA battery.
I want to upgrade the device to become rechargeable but keep its small size.
The reason is because it is a pain changing/recharging AA NIMH bateries with every use.
THE IDEA:
I thought it would be a good idea to use a type-C rechargeable flashlight to power it.
I would only have to remove the LED/reflector/head and replace them with the motor/assembly.
The motor/assembly will be transferred into a 7cm PVC pipe that will attach onto the remaining flashlight.
So far so good.
The problem is that the motor should only be powered at 1.5V/3W max.
Is there a cheapish flashlight, 1x AA size, type-C Lithium rechargeable that puts out 1.5V?
If no such product exists, then can you recommend a custom solution towards this goal?
e.g. This is just some unavailable product that ticks mosts boxes. IDK if it puts out 1.5V across the LED though.
    416.3 KB
A 14500 lithium Ion has barely anymore energy than a NiMH, so maybe you recharge every two days? Not worth the effort in my book.
You could try one of the XTAR 1.5v LiIon batteries though.
Noted. But at least I do not have to unscrew the bottom cap, take out the battery, charge it, and then put everything back together, whilst for a few hours all these bits and pieces are all over my desk, including the charger and its own box. Messy.
Much easier to just plug in a USB cable that's already on my desk always.
