Do you plan on replacing the driver/e-switch in the Zebralight? If not, no pressure switch will function correctly even if it fits the light. Pressure switches replace mechanical tail switches, they don't work in conjunction with a side e-switch like that in the Zebralight. To demonstrate - turn the Zebra on, then unscrew the tail cap slightly (analogous to releasing a pressure switch). The light should now be off. Now tighten the tail cap again (as if pressing a remote switch) and note that the light doesn't come back on. Furthermore, the UI is wholly incompatible with momentary usage.
