mdocod
First off, please don't laugh at me too hard here....
I am looking to buy an end-mill set, I've seen a number of sets for under $100 online that contain a nice selection of "normal" sizes, from like 1/4-3/4" diameter. I figure I don't need anything SUPER nice as I'm just cutting plastics.. I can't really afford to spend a lot either, but need a variety of sizes for some prototyping, any suggestions on budget end-mills would be greatly appreciated.
As some of you may know, I've been building battery adapters for awhile, I have some new design ideas that are going to require the cutting of flat bottom holes. So I figured a standard "square" center cutting end-mill would probably be my best bet... is this correct?
Assuming that is correct... I have the option of 2 or 4 flute designs. I've heard that 2 flute end-mills are better for plastics, but am not entirely sure about this.. I figure I'll be using nice slow cutting and "feed" speeds regardless as these will be used in a drill press that isn't as rigid as a true milling machine.
I may also experiment with some side-cutting with the end-mills in the press, I do have one of those cheesy 2 axis moving vices from harbor freight. I've never worked with milling bits, but am hoping that with slow speeds they don't chatter in the press..
Any thoughts or comments on this would be greatly appreciated.
If it makes any difference, I am primarily working with Delrin (Acetyl Copolymer)
Eric
Eric
