WildRice
Good'ay all. Since I started my job a few months ago, my free time has severly shrunk. I am finishing up some DD (well, with a resistor) LUX III lights. Since the LUX will be dim by the time the unprotected cell (Li-Ion) gets to 3.2v, undervoltage isnt really a problem. However, I would like to put in a LED that will trun on when the voltage gets to about 3.4(ish) volts. The circuit would only be on when the light is on, so current draw isn't really an issue.
Here is where I need your help....
I would like to build this as cheap as possible, no PICs or custom IC's. I just basically need a small comparitor circuit that will run on 3(ish) volts. I am pretty sure something could be built with a couple low voltage transistors, a zener diode, and some extra parts. If anyone has a circuit that can do this, your help would be GREATLY appreciated. Also, space is NOT an issue, as this would be going into a MAG D size space.
Thanks in Advance
Jeff
Thanks in Advance
Jeff
