<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Brock:
I wouldn't call the 6P a flood by any stretch. But the 3C is an extremely tight beam. Also, the 3C doesn't spill much light to the side. So imagine walking in a dark alley, the only thing you can see with the 3 C is what's in the spot of light. With the 6P you can see what's in the spot and still see enough to walk forward without moving the beam to your feet. Does that make sense? Now if you only want to light it a tiny spot the 3 C is the way to go. Also the 3C is about 2.5 times heavier the 6P.<HR></BLOCKQUOTE>
Herky,
I agree with 5BY5 and Brock.
I gave my SL 3C to a friend because I was disappointed with its performance both in terms of brightness and beam quality. I have absolutely nothing against Streamlights in general, and I own and respect some of their lights.
The great advantage of Surefire aside from extraordinary mechanical quality and reliability is:
1) Beam DESIGN which, aside from faceted reflector quality (which is now emulated by some other manufacturers) is cunningly formulated to give the most functional combination of central beam intensity and diameter, along with peripheral spill, combined with a carefully calculated compromise between spot and flood.
2) Unprecedented interchangeability and flexibility of design enables you to combine and put together your own "individualized" light using connection options. (Though it's true that Streamlight has started down this road also, but this isn't applicable to the 3C)
There is a non-Surefire 2 x 123 light that might be appropriate to your needs in terms of unusually long throw along with fairly decent peripheral illumination. It is the ASP Triad (originally the "Taclite") which is the longest-throw non turbohead 2 x 123 currently available. It has a "set-and-forget" internal focusing mechanism that enables you to get a beam that projects much further and stronger than any other comparable light. Note however that it accomplishes this through a somewhat smaller diameter beam (which NTL retains a functional peripheral.) The light is about the same size and weightas the SF 6P, and is owned by relatively few flashaholics. It's my favorite 2 x 123 and is also carried by one of CPF's senior security people. (I own most of the others, and I love my SF 2 x 123's but this blows them away in terms of beam throw). The light is quite inexpensive
www.tannersstorefront.com
Sorry I got on my ASP soapbox. I just thought it might be good for your specific needs.
NOTE: Any of the Surefires mentioned in this thread are excellent, but IMO the E2, though a wonderful little light, would not be adequate for your purposes. It has a relatively weak beam because of its unusually wide dispersion angle. This is fine for use as a general utility light, but not as a strong probing light.
When it comes to rechargeables, others on this board are more knowledgeable than I am.
Good luck and
Best regards,
Brightnorm
