Neew Screws for a Mod
kosPap
Naoussa Greece
Greetings all!
The past month I gave off any hope to finding a particular Imperial thread size screw here in Greece.
The screw I need is:
9/16 inch, 18 threads per inch, full thread (up to the head), hex head if possible, brass if possible and length around 1 inch (will settle with any length above that). Quantity is a dew pieces only.
What I need it is to mill an Anglelux metallic PR bulb socket to fit a MagLED
Could any member with access to these be so kind as to send me some?
(all costs covered by me with paypal of course).
"we need a crossed fingers icon here" , Kostas
I'm going to move this to 'Materials/Mechanical/Machining' for you. You are more likely to get some answers there.
I checked all my usual sources (McMaster, Enco, Fastenal) and could not find a brass cap screw in this size. It might be a hard product to find even here in the U.S. I'll check King Bolt on my way home from work...
brass cap? what is it?
Actually I can work it out with a bolt....which i will trim and bore it to accept trhe PR bulb. And need be I can use a steel one.
BTW I hope I was clear, since at times like this language and lack of techinal terminology becomes a barrier
I wrote it in a confusing manner. A "brass cap screw" is a "cap screw" made of brass. Geddit?? The difference between a cap screw and a bolt is that a cap screw is threaded to the head and a bolt has an un-threaded portion of the shaft. (I know, Americans and their weird names for things.)
Find someone locally with an old lathe that will cut imperial threads and have them turn the entire part from some brass stock.
this is precisely the reason I am searching here. Because i cannot find one willing/able to turn them.
Now it seems along with some books i will be buying also screws from amazon!!!
There should be some repair shop that specialized in older American/British cars that should have a lathe. Other than that anyone with CNC equipment can turn any thread.
no I did not. I had a look at some other sites like screwdepot and had no luck, so I gave up and howled for help.
BTW you do not knwo the cituation but here in northern Greece CNC shops are scarce, maybe a handful...if you ask them to make a couple of screws will either rob your bank account or give you a stare and put yourself on the CNC machine and be done with you....
ahhhh sometimes like this I crave to be in your area...
I may be able to find what you want; however if you have a specific design, it might be easier to send me plans and I can make the final product for you, exactly how you want it.
I mention this because you say you will modify to suit your needs. Just let me know exactly what you want (technical drawing in inch or mm is fine) and I will quote it for you.
A brass 9/16-18 bolt should be easy enough to find. Even if the thread does not go all the way to the head, it can be threaded (with a die) to have full-thread. This is very easy, particularly on brass stock, which is quite soft.
Send me a PM if interested.
PayPal is fine for payment for me too.:D
