matrixshaman
I just got some B&D VPX7 packs and scavanged the A123 systems new 18650's out of them. I currently don't have a Hyperion charger or some of the new high end chargers made to charge these that seem common with the RC users. I don't really plan on spending that kind of money either since I have no need to fast charge them like they do. I do have a huge regulated Power supply with metering that has fully adjustable voltage and current that I know will work fine for charging these BUT it's in a place that is temporarily almost impossible for me to get to. So until I can find it or another unit I've got that is also a good contender for charging these I thought why not use the Ultrafire charger that is 3.6/3.0 volt switchable? It's made for either the regular 3.6 volt Li-Ions or it will do the LiFePO4 cells that are 3.0 volt and will charge them to 3.6 volts where it cuts off IIRC. And it just happens that 3.6 volt is where the A123 3.3 volts cells need to be cutoff at based on the A123 specs I've found. I know this charger would be slow but I'm in no hurry. I'm just wondering if I've missed anything about why this couldn't work as I have not seen any mention of it.
