New AceBeam Products and Deals
freeme
Vendor
1thedeals.com
ACEBEAM X50 8*XHP70.2 40000lm 800m Rechargeable Searchlight (JULY 2021)
Price: $369 (before discount)
Coupon: 1THEDEALS ($36.90 OFF)
Proceed to Store: ACEBEAM.com
Features:​
8 x imported famous brand LEDs with a lifespan of 50,000 hours
6500K Color temperature:
Max 40,000 lumens output by rechargeable batteries pack
Ultra-Low: 230 lumens; 24hours;
Low: 650 lumens; 3,600cd; 120 meters; 11hours;
Med1: 2,250 lumens; 14,400cd; 240 meters; 3hours 40 minutes;
Med2: 6,500 lumens; 30,625cd; 350 meters; 2hours;
High1: 14,000 lumens; 55,932cd; 473 meters; 1hour 50 minutes;
High2: 26,000 lumens; 96,100cd; 620 meters; 1hour 45 minutes;
Turbo: 40,000 lumens; 160,000cd; 800 meters; 1hour 30 minutes;
Strobe: 12,000 lumens, 1hour 45 minutes;
5000K Color temperature:
Max 38,000 lumens output by rechargeable batteries pack
Ultra-Low: 200 lumens; 24hours;
Low: 600 lumens; 3,025cd; 110 meters; 11hours;
Med1: 2,150 lumens; 13,225cd; 230 meters; 3hours 40 minutes;
Med2: 6,200 lumens; 27,225cd; 330 meters; 2hours;
High1: 13,500 lumens; 52,900cd; 430 meters; 1hour 50 minutes;
High2: 24,000 lumens; 90,000cd; 600 meters; 1hour 45 minutes;
Turbo: 38,000 lumens; 140,625cd; 750 meters; 1hour 30 minutes;
Specifications:​
LED : XHP70.2 LED with a lifespan of 50,000 hours
Moonlight: 1 lumen; 11 days
Low: 50 lumens; 50 hours
Mid1: 180 lumens; 625cd; 50 meters; 12 hours 45 minutes
Mid2: 650 lumens; 1,600cd; 80 meters; 4 hours
High: 1,300 lumens; 3,600cd; 120 meters; 1 hour 45 minutes
Turbo: 4,600 lumens; 14,400cd; 240 meters; 1 hours 30 minutes
Strobe: 1,650 lumens; 2 hours 30 minutes
Max. output 4,600 lumens
Max. beam distance: 240 meters (787feet)
Max. runtime: 11 days
Peak beam intensity: 14,400cd
Premium type HAIII hard-anodized anti-abrasive finish
Impact resistance to 1 meter and waterproof to 2 meters submersible
Size: 128.3mm (Length) x 30mm (Head Diameter) x 27mm (Tube Diameter)
Weight: 102g(3.59oz.) w/o battery
IP68 waterproof (2 meters submersible)
ACEBEAM E70-TI CREE XHP70.2 4000lm 240m 21700 Flashlight – Rainbow PVD (AUG 2021)
Price: $188.90 (before discount)
Coupon: 1THEDEALS (10% OFF)
Features:​
  • Pocket-sized, compact flashlight featuring with exquisite appearance and high amount of power
  • A max output level of as much as 4000 lumens output in an ultra compact size
  • Adopts an advanced LED to give great light efficiency
  • Powered by one 21700 USB battery, equipped with a built-in USB-C port (cable included), it is conveniently rechargeable without the need for a separate charger
  • 21700 battery power source provides long runtimes for extended periods of use
  • A single 18650 battery is also adoptable (CR123 or RCR123 are NOT compatible)
  • Digitally regulated output maintains constant brightness
  • 5 Brightness levels and 2 speical modes (Strobe and Moonlight) for various scenarios
  • Utilize the most sophisticated technology to offer small device that doesn't sacrifice on power
  • Lockout mode and "double click to turn on" design prevents accidental activation
  • Smart ITS temperature control system provides stability and optimum performance
  • All circuitry contact points are gold-plated, providing better conductivity and superior durability
  • Strobe mode disorients an attacker without excessive force
  • All-in-one metal tail switch for convenient operation
  • Tail stand-capable for use as a candle
  • Ultra clear tempered glass lens with anti-reflective coating
  • Made of durable high-strength and oxidation-resistance aero grade aluminum
Specifications:​
