New Armytek flashlights - Elf C1/C2 with Micro USB
ArmyTek
Manufacturer
Armytek assures that Elf has a number of great advantages!
Why should you get these lights?
1. The flashlights can work in lamp mode without battery, in Firefly1, Firefly2, Main1 and Main2 modes.
2. They are Micro-USB-rechargeable, but IP68 waterproof and dustproof.
3. Ready-to-use set includes 18650 3200mAh (Elf C2 XP-L Micro-USB) and 18350 900mAh battery (Elf C1 XP-L Micro-USB) and Micro-USB charger.
4. These flashlights accept ANY quality 18650 battery (Elf C2 XP-L Micro-USB) and 18350 battery (Elf C1 XP-L Micro-USB) which no need special construction. Only turn off the flashlight and connect the cable.
Amazingly powerful multi-flashlights Cree XP-L, 1050 LED lm brightness powered by only one 18650 Li-Ion battery or one 18350 Li-Ion battery.
· Rechargeable flashlight with Micro-USB charger.
· Multi-flashlight “10 in 1" is for many activities: car, fishing, hunting, home, work, city, picnic, bike, outdoor, travel.
· Efficient TIR-optics and no “tunnel vision” effect even after continuous use.
· Side switch for comfortable one-hand operation and easy modes switching with advanced operation.
· Multicolor State Indication and ultra low current drain in OFF-state – more than 25 years.
· Solid body without long wires, weak rubber connectors and unnecessary boxes.
· Magnet in the tailcap, removable clip and possibility of tail-stand for multipurpose use.
· Total protection from water, dirt and dust penetration – flashlight continues to work even at the depth of 10 meters.
And as always these powerful and reliable flashlights designed by a Canadian manufacturer especially for your needs, using the components from the USA and Japan.
Items included in the package: Flashlight, clip, user manual, 2 spare O-rings, 18650 Li-Ion battery (Elf C2 Micro-USB) or 18350 Li-Ion battery (Elf C1 Micro-USB), magnet, lanyard, headband (2 straps for Elf C2 Micro-USB), plastic holder.
ArmyTek
Manufacturer
Presume it means no cell in the light, plugged in via USB and it will work or certain levels.
The flashlight can work in lamp mode without battery, in Firefly1, Firefly2, Main1 and Main2 modes. To do this, connect the cable and remove the battery. In this mode, the selection of brightness modes is carried out by holding the button. Turn on and off - click. There is no color indication in the lamp mode.
