petemalelis
- Joined
- Nov 15, 2005
- Messages
- 60
will this fit in the z52? because that would be great and when can i get one?
Good lord. We'd have to kill Don if he made a backwards one! But then, he'd probably take care of that for us if the thing ended up reverse.Lunal_Tic said:Is this a "normal" clickie or a "reverse" one?
-LT
McGizmo said:LT,
Clickie normal, me not.
Icebreak said:What about for this light?
The tailcap unscrews into two circular frames. One frame contains a Kroll that is screwed into it. It then screws into the barrel. The diameter is about 23.75mm. The other circular frame is an end cap that snugs the boot to the switch frame.
I don't know thread talk but it looks like 4.5 threads to 4mm pitch.
I don't think your new switch would match up at all but my poorly phrased question is: Would the Kroll replacement part of your switch work? I believe Doc K. mentioned the threads are different than a Kroll.
Yep. I've enjoyed this light you sold to me. I'm just about done with it except that the switch doesn't like 10 1/2 AA cells pushing a Welch Alynn WA01166 for 17 - 20 minutes.ChocolateLab33 said:Hmmmm....looks familiar.
McGizmo said:This is not a two stage clickie switch.
