Sold/Expired New Cree XP-G2 P60 Replacement Modules
Wurkkos
nailbender
Supporter
North Carolina
Re: XP-G2 / P60 STYLE MODULES
Maybe ok now,
My Godaddy Hosted sites are up and running ok. :candle:
Hi
And you are correct came back about 45 minutes ago here. Glad to be back to normal. Nasty old hackers!
Thanks
Dave
PS I am glad I did not have their headaches today!
KDM
Tennessee
I changed to a smooth reflector. My PP notes say OP, if its to late to change or doesn't get changed it's my fault. Thanks
nailbender
Supporter
North Carolina
Hi
All have shipped except for onebigdays, it is done and will ship tomorrow just waiting on PP to clear.
I did find one driver like you wanted.
Dave
justindfish
At 1.4A which would have higher output XML or xpg2. Also which would have better throw i know at 3A the xml shear output would make a noticeable difference in throw but what about at 1.4A. Either would be neutral 4000K. Im trying to get something with a two hour run time on a 3100 Mah redilast and still have the max lumens possible. I have a 3A xml now and love it just want the option of runtime sometimes it more important than the output.
Sent from my DROID RAZR using Tapatalk 2
nailbender
Supporter
North Carolina
Re: XP-G2 / P60 STYLE MODULES / COOLWHITES & NEUTRALS
Hi
I have a 2XAA host I stock with a T6 XML and it is about 340 - 350 lumens with 1.3 amps while a coolwhite XP-G2 is about 380-400 lumens. Also a XP-G2 has a beam angle of 115 degrees while the XML has a beam angle of 125.
I do agree with you about a XML running at 2.8 amps while a much wider beam the sheer output will certainly push it down range.
Pushing the XP-G2 at 1.4 amps will give you a minimum of 2 hrs and probably a bit more. Of course the same is true of the XML if pushed at 1.4 amps.
Dave
KDM
Tennessee
http://db.tt/qBkPQY2g
18350 thrower
Great drop in, love the neutral tint. Gotta have that OP reflector now. Thanks for getting it out fast also.
jmpaul320
CT, USA
dave i got my order today of the 5000 and 4000k
i now have the nailbender xpg2 complete collection (cw, nw, and ww) :rock:
i fired them both up... both are great! going to be difficult to try and choose one to use lol... ill rotate them in my hosts :)
the neutral tint is awesome!
one question - the copper tape that you provide with each dropin - do you sell that by itself? i have a number of other dropins that would benefit from having copper tape and foil gets annoying because it shreds and goes everywhere
justindfish
Hi
Dave
So it sounds like the xpg2 at 1.4A would be the choice maybe give me a little more output than the xml and most probably more throw than the xml.
Sent from my Nexus 7 using Tapatalk 2
nailbender
Supporter
North Carolina
Hi
Sure I sell it on the website, just look under the DIY section and you will find it with a few other things like GITD boots, thread lube and a few other items.
Thanks for the kind words on the drop ins. I like them all but really like the 3D!
Dave
tobrien
Georgia Highway 441
nice man!
KDM
Tennessee
(P60) XP-G2 R5 flux 3D tint 5000k
2.8-6 volts 1.4 amps
3 levels * high , med , low *
OP Reflector
Potted
$35
PP sent thanks
msim
Seattle, WA
PP sent for
LOP Reflector
Potted
(Forgot to put username in comments, payment sent from matt (at) msim [dot] tv
nailbender
Supporter
North Carolina
PP sent for
LOP Reflector
Potted
Hi
No problem thanks
Dave
Hi Dave
I have an XRE-R2 EZ900 pill driven at 1.5a in a dereelight aspheric.
How do you think your XP-G2 R5 coolwhite would compare to this in terms of lux?
Regards
joco
Kansas
Dave,
All the modules I have gotten from you have an OP reflector except the most recent High CRI XML. I love the beam on the XML, and I was wondering how bad the rings are in the XP G2 with a smooth reflector? Not white wall stuff, but outside in the real world.
Thanks, John
nailbender
Supporter
North Carolina
Hi Dave
Regards
HI
I really don't know, a XRE has a 90 degree beam angle so it will have the tightest beam but it is only about 275 to 290 lumens. The XP-G2 has a 115 degree beam angle but is closer to 400 lumens. I don't carry 900 EZ but as most know they are throw king but the added lumen in the XPG2 has to account for something.
Dave
nailbender
Supporter
North Carolina
Dave,
Thanks, John
Hi John
They certainly are more evident than the XML but in real life use I don't notice the rings. On a white wall yes but not bad enough to concern me in real life outdoor use.
Dave
PCS
XP-G2 R5 flux 1D tint
Smooth reflector
Potted
Surefire host
TOTAL: $35.00
Paypal Sent
joco
Kansas
Thanks for the info, Dave. Paypal sent for:
XP-G2, R5 3D 5K
2.8 - 6 Volts, 1.4 Amps
3 level, Smooth, Potted.
John
