@Rush
Any updates on new driver?
Are these reverse polarity protected? Could I just flip the battery over to prevent it turning on?
GoVegan,
the Hive drivers are all reverse polarity protected, you don't have to worry about inserting a battery the wrong way.
id30209,
there is a working prototype of the new driver but i am not happy with the performance yet, so more work is needed on the design.
Thanks for the encouraging words F89, i certainly do my best to improve on the shortcomings of the current HiveLD. I would be another happy user![]()
Hi, I'm looking at ordering a haiku but read about the hive pwm issues on low lumen settings. I'm just wondering when rush does update things to address this issue, does it mean new hardware? In which case I might be better off waiting for the update before I order the haiku?
Thanks for sharing your thoughts id. Perhaps I should have mentioned that the 3S also uses PWM on it's lower modes, I'm quite susceptible to PWM but I don't see it on the 3S and don't think anyone would. The current Hive however, the PWM on low modes was quite obvious. I used to use 660nm red in the army, it's pleasing on the eyes but terrible as far as being monochromatic and tactically pretty useless as even tiny amounts of red light (any light) literally light up like a Christmas tree when using NVG :candle: It does a pretty good job if used low enough not to mess with your dark adjusted eyes but then again so does white light if used low enough (needs to be quite a bit lower than 660nm). Currently I don't find I often need moonlight levels. That said, if the reworked Hive came out I'd snap up a couple for its moonlight ability amongst other things.The only problem with PWM is ultra low levels which you won’t see or use if you choose standard 3S operation in UI. That’s why i don’t see any flickering in my setups but i’m not using super low levels at all. For night expedition i’m using 660nm red light. Sent from Tapatalk
So reading through this, yall only see the flicker (PWM) through bridging the contacts and accessing the lower output settings? I just got my first Light from Don, and I can't see any flicker on the lowlow setting..... ETA: Haiku/HIVE/123/Nichia119v
thanks!
Ok thank you for the info! Glad to be learning all this. Ordered an AA mule so I’ll have both engines!
Not sure if any of my ramblings help (or further confuse?) but I encourage you to continue your interest.
Very helpful, I always enjoy reading your posts and actually came across another of your post raving about the 1xAA + AA LE on the Haiku. That has swayed me and I've gone ahead to order an AA Haiku with Don. I did opt for the osram LED as I'm curious about it and we're spoilt for choice popular Cree. But then of course the cree are popular for a reason, so I might regret the osram?
I do already own a Mule 1x123 with 3S 119V. If I do feel like it, can I swap the 123pak and 3S 119V into the Haiku head and effectively have a Haiku 123 w/ 3S 119V? Will the reflector in the Haiku be compatible such that the result is exactly the same as if I'd other that configuration new from Don? And vice versa, if I swapped over the 1xAA w/ AA Osram into the Mule, will it be the same?
p.s Does that mean I could also then mix the 1xAA pak with the 3S 119V + Haiku (or Mule) head and be able to run 14500 cells? And would a 3S 119V + 123pak allow me to run CR123 primary?
I'm glad you've enjoyed my ramblings.
In my experience the tint on the 119v, looks nearly identical to the sw45! It has a very nice, slightly rosy tint.
