Hi Archimedes,
Good questions.
The calibration sets the zero point of the output and the maximum current defined in the respective setting. All level outputs scale to that maximum output.
Hence in case 1 there is no need to calibrate.
Case 2 will therefore need recalibration and the driver automatically does so when you change the maximum output setting after leaving the setup mode.
A LED change does not require a recalibration in most every case, at least as long as you stay in the realm of white LEDs that have comparable forward voltages. If the LED forward voltage was completely different then the calibration might need a bit of a tweak to be spot on and it would make sense to do so.
You cannot damage the driver by not recalibrating. If the swapped LED would not be able to deal with the original high current then of course it could be damaged but otherwise neither.
I hope this answers your questions 🙂
Good questions.
