Looks like a boost on Turbo only. What is the point here?
They made the low mode even higher, unbelievable...
If the new light is only 10% stronger and it takes 25% - 30% more lumens to actually "see" a difference, what is the point here? Are there some new features? The run times are similar. Does anyone know the price of the new light? If they name the new one PD 35 2014 will the previous one be discontinued? It seems to me they'd have to move up to 1500 lumens or 2000 lumens to make a real difference and that's probably impractical in a light/battery system of this size.
I am very impressed by the runtime much higher..
Old version
New version 2014
maybe the batteries they use for testing is different,otherwise,the new version's runtime can not be so long
Old version
New version 2014
The run times aren't dramatically longer and only in the mid-range not at the higher end. Besides we'll swap out an 18650 at 3400 mah long before run we need to be concerned about a little more run time.
I agree. I'd like to see less hype and a more functional light. Specifically, less modes, a low low and a true high mode without all the step downs and burst modes. Beyond the marketing, it really doesn't matter.
I use my PD32UE occasionally and often switch between turbo and burst just to compare. I can hardly tell the difference most of the time. And the burst certainly doesn't let me see anything I'm "missing" with the turbo...it's just a little brighter overall.
We're talking 400lm vs. 740lm here! Sounds huge on paper but it's not.
I would use this light a lot more if it had more reasonable modes. Dump the hype, add a low mode, less trash to cycle thru:
1lm, 80lm, 500lm or something like that. Just my opinion; I'm sure some like a lots of options though. And of course, my recommendation would KILL the marketing departments. So it will never happen. It like taxes; once it's there you can never take it away. Since the 950lumens are there, and needs a low, they're forced to fill everything in between. The gap keeps growing.
