new headlamp
i dont mean to hijack the thread but im also looking to buy a headlamp for fishing/camping in general. And since im a new member and for some reason am not allowed to start a new thread i figured i would ask it here. Do most people go with a single bright LED (either 1w or 3W) or with a headlamp with multiple LEDs which has a much longer battery life?
I was thinking either a 1W headlamp or a 20 LED headlamp for longer battery life. Any suggestions?
Get ready to have your thread deleted. I asked a similar question about another headlamp WITHOUT posting a link and the thread was gone in no time.
Apparently, it's not ok to ask a question about a light you don't own...
The New 130lm apex will be as bright as the stenlight in that picture and will cost a fair bit less than either light. Not available across the pond yet.
£65 is cheap? not in US dollars!
The link is to a review, not advertisement for a dealer.
we all want the perfect headlamp. high quality but low cost.
adjustable beam from flood to a focused spot
adjustable power -dimmer- so you can dial your output at the twist of a knob.
long battery life + no sudden cut off blackout due to stupid circuitry.
rugged - survive 5 foot drop to the floor and then stepped on -haha!
waterproof or resistant, or just works in a heavy rain. :)
I'm not sure I'd want a dimmer even if it was an option.
I rather like having a few reasonably distinct light levels that I know the power consumption of, and being able to control 2 LEDs from one simple switch.
That describes the Energizer Hard Case Pro Cree. High quality, only $36. Flip up diffuser for the LED's. 2 mode white, red, and green. Light has very good pseudo regulation on NiMH and good runtime with no chance of suddenly being left in dark. Water resistant and survives a 15ft drop.
good point uk caver! knowing the burn time left. Maybe some indicator meter like scuba divers have for how much air is left in the tank. The color changing led is not good enough. I want real minutes and seconds info. 20% of what? gimme a break !
Personally, I'm not too bothered about a remaining power indicator, at least for my underground lights, since I'm almost always starting from a fully-charged battery pack, and with a gentle tail-off of light once the batteries are fairly well discharged, I'm not going to be surprised by sudden darkness, especially since I don't run off Li-Ion.
If I want to check the state of the my battery pack, I just compare my high and medium power levels - if they're distinct, the battery is good (>20% charge), if they're close or indistinguishable, the battery is fairly flat.
For longer-term predictions ("Is my pack 1/4 used, or 3/4 used?"), I can make a fair guess from usage history.
ive just been looking at the lupine betty xpro headlamp at 1500 lumens thats one bright light
Re: Raptor One, new headlamp
Thanks, the Raptor One looks interesting. Trying to Google emitter type with no luck. More specs, the better (lumen and throw specs, please). Depending on specs I will find for the Raptor One, I think $100 USD is a good price for a 10+ hour runtime, at over 250 lumens.
$100 just bought me parts and supplies for all local materials home built 10 hour running 200+ lumen headlamp: a duel head, using XR-c (Coleman thrower head $20) aside a Rebel 80 (Sears goose neck flash light-on sale for $14-- 2 watt 150 lumen smooth 8 degree reflector for $26), running off one 6 volt 1 lb. (with AA in series. Variable pot $3, $2 holder, $4 Amazing goop glue/hot glue, with up to 500 Milli-Amp current (xr-c max current spec); so, probably on order of up to 240 lumens (2 watt per head). Cost, typically $70-$80, plus charger ($15 Shack UB 640), (one $20 charger can do several batteries in parallel.). It took 2 hours to build, based on previous designs, then hour cleaning up and testing. Next day, I spent another 3 hours testing, adding padding, and tweaking. There are things I would do differently if done again ( I would insist on each light head mounted on opposite sides of head for balance, I would add wire adjustment to XR-c head rather than Velcro repositioning adjustment system.) Good color rendition, great throw and corona-brightest light yet, even dialed down to 100 milliamp. My only concern is if it might be too bright on low for close in work, durability (less hot glue than in past and more amazing goop/more coil wire used, alligator with screw downs/industrial velcro and elastic used), ease of xr-c angle adjustment with my current setup, long term agm life, and portable practicality. Years ago, I found I could distract from my looks with my head lamp. I think this light ugly enough to make even me look good.
Had an idea for an alert circuit for regulated headlamps that would trigger
a short run of one of those vibrate alert devices used in cell phones.
It would get your attention alright clamped to the forehead! haha!
No need to take the headlamp off and look at a colored led to determine
if your running low on power. Many times you can be busy and lose track of
time. A vibrate alert built on a voltage sense circuit would do the trick.
A built in current indicator is what I would love. It would not only allow total control of runtime and brightness, but alert of fading batteries.
Yeah, could just carry a mirror to see led indicator, unless using external battery supply. (My 4 AA elastic band necklass holder has been working out fine, except it gets tangled in my necklass mp3 ipod.)
(I might get pics of the described light. But should be working on other projects, like weatherizing house.)
