Here are photos and descriptions of the new range of Hope LED lights.
All the new lights use Seoul P4 emitters, are CNC machined, offer regulated light output, have four power levels and a flashing mode.
First up is the Vision 1 LED
Next up is Vision 2 LED
Lastly is the Vision 4 LED
The 4 LED light has a dimpled front lens which diffuses the light so that there is no real hot spot or any dark patches, this has been specially made for Hope.
http://www.flickr.com/photos/22689020@N05/2226049219/
The 2 and 4 LED use the case as a heat sink.
The great thing about these lights is that Hope are very forward thinking, as new technology becomes available you will be able to send light back to Hope and they will upgrade it for you with the latest emitters/bins etc (or you can mod it yourself of course).:twothumbs
I've only seen beam shots of these lights, the 4 LED looks to be better than the Lupine Wilma 4 and very close to the Betty 6. The spread of light is more even than these lights as well.
Below are some other photos.
http://www.flickr.com/photos/22689020@N05/2226829348/
http://www.flickr.com/photos/22689020@N05/2226021789/
http://www.flickr.com/photos/22689020@N05/2226808402/
http://www.flickr.com/photos/22689020@N05/2226806870/
http://www.flickr.com/photos/22689020@N05/2226015347/
- £79
- 240 Lumens
- Burn time 2hrs 45min's to 36hrs+ on low
- Uses 4 AA batteries
- +/-4 degrees beam angle
- 3.5watts max output
- 110g
- Offered in four colours
- £195
- 480 Lumens ( up from the previous version)
- Burn time 2hrs to 35 hrs on low
- Comes with softpack 2 cell PVC battery 2400mAh and smart charger
- Endurance pack of two 2 cell batteries or a 4 cell epic pack offered
- Uses two spot beams +/- 6 degrees
- 7 watts max output
- 280g
- Thermally managed
- £299
- 960 Lumens
- Burn time 2hrs 15 mins to 35hrs on low
- Comes with softpack 4 cell PVC battery 520mAh an d smart charger
- endurance pack of two 4 cell batteries offered
- Uses one spot beam and three flood beams +/- 15 degrees
- 14watts max output
- 415g
- Thermally managed
