New Icon Irix Headlamp
Candle Power Flashlight Forum
Help Support CPF:
Im very interested in your run time tests on low Beacon. I dont have the patience for those, but am doing another on one high.
Are you starting with alkaline, lithiums, or Ni-MH?
I'm sorry, I re-read my post and didn't mean what it sounded like. I understand that you meant low but I was asking if you guys think that I am expecting too much with only getting 2 and a half hours on high with an eneloop... I guess I should try an alkaline.
Capt. Spaulding, 2 1/2 hours on high is pretty good actually, that comes out to 150 minutes. Look at some of the single AA handheld lights and see what their runtime is at high. Some aren't even an hour. For runtime, low is where it's at and I am starting the runtime on the IRIX I this afternoon. IRIX II will follow the conclusion of the first runtime test.
Oh ok. I guess I just thought these 5mm led's wouldn't use as much power and I guess the 100 hour on low claim made me expect more on high. It's cool, you're right 2.5 hours is no slouch! I'm going to try an alkaline just for grins.
I started a runtime test at midnight last night on both the IRIX I and II as well as a 4Sevens Quark AA (running on a single AAA). The IRIX lights were set to low and the Quark was moon mode. I got to say, other than a wider hotspot with more flood, the IRIX lights seemed pretty much as dim as the Quark moon mode. This is a good thing. If this gets the runtime advertised at, these will probably become my favorite headlamps. I did compare the IRIX beams brightness to other low lights like the ReVO and the ReVO was much bright on low which is 1.5 lumens and the IRIX are supposed to be 5 lumens on low (which was one on the reasons I wasn't looking forward to an IRIX since a 5 lumen low is too high for me) but as I said it has about the same brightness as Quark moon, and in fact the hotspot on the Quark moon has more intensity that either IRIX. This was welcome news and now we wait to fine the results of the runtime test.
I don't wear glasses, but with the same design, I would think they would both have the same issues if one has glare for people that wear glasses.
Thanks for the info. As one who wears glasses, a headlamp that causes glare is pretty hard to deal with. While these look pretty cool, I think I'll stick to my Saint Minimus.
IRIX lights on low @ 35 hours looking the same as when I started Sunday night at midnight.
Beacon, I gave the current draw from the battery in a previous post.
High was .7A and lowest Low was .025A. Just divide this number by the mAh of your battery to get run time. Probably should multiply by say 85% to account for driver efficiency as it converts the 1.2V of the battery to 3.2v to 2v (3.2v on high, 2v on low).
Ex. on low: 2000 mAh Eneloop on low @ 0.025A = 2000mAH/25mA = 80 hrs * 85% = 68 hrs. With an alkaline or lithium bat, capacity is around 3000mAh which gives around 100 hrs. Actually I think lithium's (L91) are around 2850mAh but nominal voltages is higher which should improve efficiency a bit.
Ex. on high: 2000 mAh Eneloop on High @ .7A = 2000mAH/700mA = 2.86 hrs * 85% = 2.43 hrs. L91 should be 3.64 hrs.
BTW, Spaldings post giving 2 hrs 20 min or 2.333 hrs on an eneloop gives an efficiency of 81.7% on high which might be a more accurate efficiency number to use, at least on high.
