I called customer service at Maha and asked if they recommended a break-in for the Imedions, should you own a C9000 charger. I was told that while you could use them without break-in, they did recommend break-in for the best possible performance. Furthermore, no discharge is necessary, nor even preferable, before doing the break-in. The service representative explained that you can't damage even a fully charged battery in 16 hours, by breaking it in at 0.1C.
Is this hard to believe that you need not discharge these batteries before break-in? It was for me. I called Maha a second time and spoke to a different service rep and got the same answer. So unless Maha wants us to fry batteries and then buy more, I would guess their advice should be trusted. If we can't trust their advice about their own products, then who is the final word?
It occurs to me that we can just let our common sense be our guide.
Regardless of whether or not a fully charged cell can be damaged by a .1C rate of charge for 16 hours, we only have to keep in mind the reasons we are subjecting our cells to the forming or break-in charges in the first place.
As I understand it, one is to break up large chrystals to reduce the cells internal resistance and prevent separator perforation; another is to better integrate the elecotrolytes, which also helps to prevent the formation of hot spots, especially under high discharge rates.
Combined, these processes generally act to increase our cells capacity, performance and longevity.
Since the most essential part of the process appears to be the slow, deep discharge, why wouldn't we get a head start by doing one at the outset, especially when it will allow the first charge at .1C to better do it's thing as well?
Regardless of MahaEnergy's statements to the contrary, they are never going to convince me that pumping 3360mAh into a fully charge cell isn't having a detrimental effect.
I am also sure they will never advise us of the converse, being that it's actually benefiting our cells; something we do know conducting a deep discharge most assuredly does.
MahaEnergy's technical support just slipped a little in my esteem.
