I have a request for a Ti spear/javelin that's going to be 30" long. So now I'll finally need an outboard spider. Time for me to make one too & here's my version which will thread into the spindle.
Spindle thread is 1-5/8-16. My spindle bore is 1.535" at it's smallest point on the gear train end. so I'm able to fit 1.5" stock all the way through with no issues. YMMV as some have reported their spindle bore to be just under 1.5". The bore is larger towards the chuck side.
Started out with some 2"Ø CRS.
Used the 4 -jaw to face & center drill both ends.
I only have a pitch mic for external threads that has a 1" capacity & I haven't messed around with thread wires yet so I'll be turning between centers.
Used my custom Android app to calculate thread depth (I may have given some of you guys the PC app which has evolved to Android now with a few more calculators.
Will, Barry, Ray, Dan & Bob, if you have Android devices and are interested send me a PM or email
Test fit, not enough depth & need to tweak the major Ø.
So back on the centers a few more times until I was happy with the fit.
Now it screws in all the way & I'm happy with the fit.
Drilled up to my largest bit on hand, 1". I've been wanting to get the larger set of S&D drills but I'm not sure if it's worth it & I wish I had one more lower spindle speed around 30 rpm. I use the cheap China S&Ds, they work fine for me even with Ti 6-4.
A Fowler electronic edge finder showed up today as I've been curious about them. At $30, cheap enough to give it a try. Have to be real careful with this solid type as the tip does not "break away". It works by contacting the metal & continuity through the mill (to think, the tip contacts the work piece, then through the chuck, super spacer, table, base/leadscrews, column, to the head, then the spindle, collet, & finally the edge finder's body, what a journey). I may try the more expensive break away ball type tip later but they have their limitations & advantages because of the ball. Just testing it here, I still just used the good ol conventional edge finders.
Used the SS to drill, tap, & chamfer four holes.
Back to my little trusty Enco 4x6 to cut off the excess. If you haven't noticed, I made a pull out tray using a thick aluminum baking pan that's mounted to the frame. No more using a cardboard box anymore sitting under the middle tray & fine chips all over the place when using it. Keeps the middle tray much cleaner too now. Those slides for the tray was the very first thing I made on the mill.
Final boring to allow 1.25" stock to fit through comfortably.
The finished spider. Really wish I had some better steel on hand than 1018 but this should last me a while.
Now I can continue on with the Ti javalin....
Thanks for looking!
:wave:
