precisionworks
Really glad that worked out, Will. As you know, there was very little extra material left, something less than the thickness of a sheet of printer paper, and it concerned me that I might have taken too much off :thinking:Filed & sanded for a tight fit
There's another way to tighten up a loose fitting T-nut, one that is sometimes used on a table saw miter gage. Drill and tap a couple of holes on one vertical face of the T-nut, and install allen head set screws so they barely project above the face. It isn't hard to set them so there's the correct drag. On a miter gage, the screws are set into the side of the bar:
Gits makes them & McMaster (and others) stock them ... but the Gits oiler is nickel plated steel.replacement oiler
http://www.gitsmfg.com/gits-oil-hole-covers-style-gb.htm
