New light for Police Patrol
Etan
Currently I have an older Stinger XT which is absolutely awful, and a 4Sevens Quark Turbo 123. The old Stinger is absolutely terrible and it just sits in the charger in my car. I love my 4Sevens light except for the fact that it runs off of CR123 batteries that I am constantly replacing and since I keep it in my pocket I would like to reserve it for a seondary backup light.
Currently I am borrowing a Stinger DS LED HP from another officer and I really like this light. I am wondering if there are any other lights I should be looking at. I am looking for a larger size light, the ability to tuck it in my armpit while handling a traffic stop, and being able to charge it in my vehicle would be a big bonus but I am ok with being able to charge at home. I would like to stay in the same price range as the Stinger, approximately $100, and have the same or more light output. I would prefer a light with even more throw than the Stinger if possible. I mainly use the light for being out on foot and scanning neighborhoods and fields.
Another officer has the terralux upgrader on a Stinger XT but that doesn't provide enough light for my preference. I plan on getting one of these kits eventually and making my old stinger at least useful.
==================Flashlight Recommendation Checklist================
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
_X___This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
____Up to $25.
____Up to $50.
____Up to $100.
__X__Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
_X___I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
_X___MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
_X___LED (known for efficiency, longevity, and compactness)
_X___HID (known for max output, but often at the expense of size)
____I don't know.
6) Manufacturer:
_X___I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
_X___I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
_X___I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
_X___I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
_X___I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
_X___I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
_X___I want search and rescue type illumination (800+ lumens).
_X___SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
_X___Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
_X___Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
_X___50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
_X___150+ yards (I am searching from a helicopter)
____30-60 minutes (I have plenty of batteries just ready to be changed)
_X___90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
_X___Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
_X___I don't care.
____I don't know.
____A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ---...--- emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
_X___I don't care.
____I don't know.
14)Material/Finish/Coating
_X___Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
_X___Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Water resistance
____None needed
_X___IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
_X___In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_________________________________________ ____
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
NotRegulated
If you like the size of the Stinger DS LED take a look at the Malkoff Hound Dog XM-L with the MD4 body. It is virtually the same size as the Stinger DS LED but it's output far exceeds the Stinger. Use two protected rechargeable 18650 li-on batteries to power it. This light will also take 4 CR123's which is important for emergencies and/or extended deployments.
____Up to $25.
____Up to $50.
____Up to $100.
__X__Up to $200.
____Up to $300.
3) Format:
4) Size:
____I don't know.
6) Manufacturer:
_X___I don't care
____I don't know.
_X___I don't care.
____I don't know.
_X___I don't care.
____I don't know.
____I don't care.
____I don't know.
____None needed
____Holster
mcnair55
North Wales UK
Try the blue light industry stores they have amazing lights on offer and often run by real enthusiasts from the industry.
Dave D
Andalusia, España
+1 on the Malkoff Hound Dog.
However a cheaper alternative is the Nitecore MT-40, looks like a traditional style duty light, runs on two rechargeable 18650 batteries, with good throw and has the following outputs/run-times 860Lm/1.5hrs, 530Lm/3.5hrs, 280Lm/7.5hrs and 100Lms/24hrs.
Those run-times are based on 2 x 18650 2600mah batteries, there is a 3400mah version now available which should substantially increase those run-times.
Review of MT40 below
http://www.candlepowerforums.com/vb/...EAMSHOTS-VIDEO
historyfuzz
I went through this recently while testing new lights for my department. After testing over 35 lights, I can offer the following:
1.Based on the size you described (and I totally understand the functional aspects of this), your buddy's light that you borrowed, the Stinger LED HP DS is the best value in this category.
2. A close second, and also a light with a strong bean and good profile is the Eagletac SX25L2: https://www.eagletac-usa.com/products/product.aspx?pid=1-44-7187 . It's well made and about $150. The only downside is that it doesn't have a tail switch. It will last twice as long before charging than your buddy's Streamlight and the charger is built into the light. Don't get the turbo model as you won't like the beam.
3. There is no production light that produces a more practical beam pattern with the incredible brightness that a Fenix TK35 UE produces. It is remarkably powerful and floody. I've found only a couple of lights like it and they are twice its size. I can tuck it under my arm fine, but it is not as long as the others.
4. If you want something classy and very well made, as well and powerful and that fits your size requirements, the Surefire Lawman R1 is nice. I wouldn't want to drop it thought (and you know that we drop lights all the time) since it costs around $299. Cool light though.
5. The Fenix TK 75 is a floody and throwy light all in one and simply one of the most powerful lights on the market. It is big though and changing batteries mean taking out a carrier. It's more for search and rescue.
6. The Eagletac MX25L2 with an SST-90 LED looks like an old school Maglight or Streamlight SL20, but a bit shorted and lighter. It is extremely powerful, just shy of the TK75's abilities. It is the next size step upward from the SX25L2 I mentioned above. The GX25L2 is the smallest of the trio. Neither the MX25L2 or GX25L2 have a tail switch either, and these two lights will not last as long as the SX25L2.
7. Lastly, Streamlight just came out with a C123 three-cell light you might take a look at. It runs about $100 and can run perfectly on two rechargeable 17500's which makes it affordable to buy and run. Surefire has virtually the same light at twice the price (P3X Fury) that will also run on two rechargeable 17500s and these are both long enough to tuck under your arm and sit well in a belt holder.
There you have it--the fruits of my humble research. I hope that helps. Good luck. 1) How would you prefer to purchase the light?
____Up to $25.
____Up to $50.
____Up to $100.
__X__Up to $200.
____Up to $300.
3) Format:
4) Size:
____I don't know.
6) Manufacturer:
_X___I don't care
____I don't know.
_X___I don't care.
____I don't know.
_X___I don't care.
____I don't know.
____I don't care.
____I don't know.
____None needed
____Holster
weez82
pacific northwest
You could get an AW 17670 and a single or dual bay charger for under $20. That would keep you from buying cr123's all the time :)
EDIT:
Also have a look at these outdoor beam shots, to get an idea of whats out there. Might even see something you like :)
https://www.youtube.com/playlist?list=PL5DCCDFBD44A19BCB
https://www.youtube.com/playlist?list=PL084D0F0F60B1C690
NotRegulated
If you like the borrowed Stinger DS LED HP you may want to stay with that since you can still utilize the charger in the car. Make sure you get the newer version with the upgraded LED rated at 350 lumens peak output. There are many places on the web that are selling the older model rated at 200 lumens. The lights are identical except for the LED.
I have no experience with the Nitecore MT40 but for the price it may be worth looking into or trying. The Malkoff Hound Dog will cost considerable more but I know it is top quality with great warranty. With either choice you will need to invest in two 18650 batteries and a charger. These two are by no means your only choices.
I commend your decision to carry two lights. Good officer safety. You utilize your radio and your lights constantly. Best to you with whatever you chose.
Unicorn
Near Seattle, WA
The 680 lumen magcharger LED maybe? Perhaps a bit big though.
The stinger HP is a good choice since you already lime it, and it uses the same charger as your current stinger. Too bad they don't use make an HL version of the HP also. 500 instead of the 320 lumens. Wouldn't throw any further, but a broader beam.might be nice.
If you go with rechargeable 123 batteries, you'd need to keep a lot with you, and maybe have a car charger. You'd only get about 20 minutes per set of batteries. Not a long time if your searching a large area.
mcorp
Singapore
How about Estrela from Night Reaper Systems. Meets all your requirements and is under $200, 1000 lumens, accessible strobe if need be, runs on 18650 battery which comes with the flashlight and also comes with a nice holster and battery charger.
A complete package :)
makapuu
Honolulu, Hawaii
One light that I have and really enjoy is the EagleTac MX25L3 Kit with a MT-G2 emitter. The Kit version has 2 clickys, one on the tailcap and one on the side. The spill is very bright and it throws about 45 to 50k. The beam has a very smooth transition from hotspot to spill. You could also get the light with a XM-L2 installed for more throw. But I would probably get a different XML light instead, because I feel the MT-G2 is the emitter to get for this light. I also like the neutral tint that the MT-G2 has. The one feature that I like is instant turbo from any of the lower modes. All you have to do is press and hold down the tail or side clicky. When you release, you go back to whatever lower mode you were in. The light is within your budget, but the price is still a little high. You would have to keep your eyes open for a sale, that's when I got mine.
historyfuzz
They actually do have an HL version at 640 lm: http://www.streamlight.com/en-gb/product/product.html?pid=273 , which I mistakenly thought he was talking about from the beginning. The HL is a great light and the best value and with a practical beam (as you suggested). The HP has a bell shaped head and throws far, but it has very little spill.
NickSwan
Florida
Not sure how big your agency is, but my agency provides all the CR123s we could ever need through supply! We use them for our optics and flashlights and can't afford to have a dead battery in a fight. Maybe it is time to have a talk with your Purchasing/Supply guy/girl...
