[NEW] Lumintop X9L SBT90.2 6500lm 810m 21700 Flashlight
freeme
Well-known member
Vendor
1thedeals.com
[h=2]
Details: https://www.1thedeals.com/product/lumintop-x9l-sbt90-2-6500lm-810m-21700-flashlight/
Specifications:[/h]
  • [*=left]Emitter: Single LEDs on a copper DTP MCPCB e.g.
    [*=left]Luminus SBT-90 LED
    [*=left]Optic: Aluminum smooth reflector
    [*=left]Lens: Glass with anti-reflective coating
    [*=left]Flux: ~6500 lm
    [*=left]Intensity: ~163,800 cd ANSI throw ~810 m
    [*=left]Firmware: The X9L uses free software called Andúril, distributed under the terms of the GPL v3. Code is available from http://tiny.cc/TKAnduril
    User interfaces:
    • [*=left][1] By default the X9L is set to use SMOOTH RAMPING. Instant access to TURBO mode is also provided.
      [*=left][2] A more conventional STEPPED RAMPING UI is available if you like discrete modes level. You can choose how many steps you want.
      [*=left][3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets. To exit this mode, physically disconnect power
      [*=left][4] MUGGLE mode uses a reduced output.
      [*=left][5] It has an electronic LOCKOUT for safety, but acts also as momentary low light.Other functions: Battery check, sunset, beacon, tactical strobe, party strobe, bike flasher, candlelight, lightning storm
    [*=left]Battery: One flat-top or button-top 21700 cell. An unprotected cell is recommended.
    [*=left]Max. length 70.5 mm. Cell is not included.
    [*=left]Driver: FET+7+1 driver. Low parasitic drain while OFF
    [*=left]Body: Aluminum with hard-coat anodizing
    [*=left]Switch: Electronic tail switch
    [*=left]Ingress rating: Equivalent to IPX7
    [*=left]Weight: Approximately 126.3 g without cells
    [*=left]Size: 40 mm Ø head x 123.6 mm length x 25.2mm tube
