Well, I received my Ti AAA Maratac and overall I am pleased.
Initial impression was that, particularly without a battery, the whole light feels rather like a plastic toy due to the light weight, actually I swear the battery is much heavier than the light. I may be biased though as I like brass lights for EDC. First thing I did was clean up the threads and test them, and being that this is my first Ti light, I was unprepared for how ungodly awful the threads are. With further inspection I found that the threads themselves are machined almost as nicely as my Brass Maratac or Brass Eiger, however the galling nature of Ti lends a nails on chalkboard feel of grittiness, which grease does nothing to alleviate and I am hoping that they smooth out a little with use per comments above.
The overall finish appears to be machine finished, no polishing or other finishing appears to have been done. This lends a very grippy matte feel to the light. The knurling of the light is unlike any other Maratac light I have in that the ridges of the knurling have been machined flat like the Peak Eiger's knurling, except that a slightly deeper cut has also been left on the knurling, compensating for the loss of the ridges. The result is that the knurling is less aggressive, but grippier if that makes sense.
The keychain attachment is the usual crummy Maratac ring attachment which I have never used due to reliability concerns. The clip remains the less than stellar, but still quite serviceable friction clip. Reversibility of the clip remains an option for those who like clipping their light to a hat.
Differences between the Brass and Ti Maratacs are as follows, the bevels on the head of the Brass light are deeper, leaving a more rounded edge as opposed to the shallower bevels on the Ti head. The grooves on either side of the knurling of the Ti head are a little wider where the Brass ones are narrower. The major difference however is in the head itself. The Ti head has the metal ring around the LED and what appears to be a different circuit underneath the positive terminal. Upon observation the light appears to be PWM free where the Brass uses PWM though it isn't noticeable unless you are looking for it.
Brass vs Ti, the threads are superior on the brass, no questions about it. The brass threads are silky/buttery smooth. This also means that at least for now, one handed operation of the Ti is difficult. The Ti threads are also looser than the brass with noticeable play up and down while the threads of the brass are tight and display such play.
In the my case I was a little disappointed in the tint since my Brass model has a rather nice "clean" cool white tint while the Ti model has a slight purple tinge though not nearly as bad as my Stainless AA model.
Overall it seems like a nice light for the money, particularly in Ti. Light weight and should hold up fine to normal EDC use.
If deciding between the Ti and Brass I would say that unless you are a weight/Ti freak or can live with the PWM, that the Brass is the better option due to the lower price, superior threads, and lower visibility of scratches.
Hope this helps some.
Lights shown below: Maratac AAA Ti and Brass, Peak Eiger w/ Prometheus Clip & narrow NW head, Maratac AA Stainless w/9x8 Turkshead in .9mm
Note the different circuits under the positive terminal.
The different bevels and the metal ring in the Ti head are visible here.
